Introduction: Miss La Sen Recycling Lantern
Miss La Sen is fictional character in Sorim Story boardgame, Miss La Sen spring rolls, comic books, cartoon clips...
Step 1: Download This Pattern for Miss La Sen Shape and Print It in A4 Size Paper.
Step 2: Use an Old Plastic Bottle, Minimum Diameter 10cm. If It Has the Smaller Diameter, the Heat of the Candle Will Affect to the Plastic Lantern.
Step 3: Cut This Old Bottle Into 2 Parts. Take the Bottom.
Step 4: Cut a Rectangle on the Plastic Bottle. Use the Hemp Strings to Roll Around the Bottle. Except the Rectangle Hole.
Step 5: Use the Glass Paper. Cut a Glass Paper Rectangle Which Is Larger Than the Hole.
Step 6: Glue the Glass Paper Rectangle Onto the Bottle.
Step 7: Make 2 Holes on the Bottle and Use a Zinc Wire to Connect 2 Holes to Hold the Lantern.
Step 8: Use the Bigger Hemp String to Glue Around the Rectangle Hole.
Step 9: After Glueing the Hemp String Around.
Step 10: Cut Miss La Sen’s Head on the Foam or the Art Paper.
Step 11: Cut the Flower, Headband and Glue Them Onto the Head.
Step 12: Cut the Dress.
Step 13: Cut the Bow, Eyes, Mouth, Cheeks, Arms... and Glue Them Like the Picture.
Step 14: Glue Miss La Sen Onto the Lantern. Use the Big Hemp String to Make a Bow on the Top of the Lantern.
Step 15: Use the Burlap Fabric Sheet to Wrap the Zinc String.
Step 16: After Wrapping the Zinc String.
Step 17: Done. You Can Put the Tea –light Candle in the Lantern and Burn It.
Step 18: You Can Hang It on the Tree, Wall...
Be the First to Share
Did you make this project? Share it with us!
Pi Day Speed Challenge
Trash to Treasure Contest
Sculpt & Carve Challenge
