A miter cut is made at an angle other than 90°, with
the blade vertical.
A bevel cut is made with the blade tilted over.
A compound miter cut is a combination
of a miter and bevel cut.
STEP 1: Adjusting for a Miter Cut
Flip the miter lock lever up (horizontal).
Push down on the miter detent lever with your thumb.
Rotate the saw to the desired angle.
If using a common angle, the miter detent lever will drop into position.
Push the miter lock lever down.
STEP 2: Adjusting for Bevel Cut
Flip the bevel lock lever up.
Rotate the bevel dial if needed.
For fine control, use the bevel adjuster on the front of the saw.
Push the bevel lock lever down.
The bevel lock lever must be in the down position before cutting.
Check the fence for blade interference.
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
