Mobile Control LED(Arduino+Bluetooth Module)
Intro: Mobile Control LED(Arduino+Bluetooth Module)
Hello,
In this instructable i will show how to control LED from Android phone using Arduino Uno Board and HC-05 Bluetooth module.
In this Arduino code is explained.
For Android code refer...
https://www.instructables.com/id/App-for-Mobile-Control-LEDArduinoBluetooth-Module
STEP 1: Requirements
Hardware:
- Arduino Uno board
- Bluetooth Module(here HC-05)
- LED
- Male to Male wires
- breadboard
- Android Phone
Software
- Arduino
STEP 2: Circuit
Make circuit as shown in diagram above.
Note: connect VCC and GND of bluetooth module to 5V and GND of Arduino respectively.
STEP 3: Arduino Code
You can download code (led.ino file)
code is to turn ON ,turn OFF and adjust the brightness of LED.
boolean led= false;
char command; String string;
void setup() { Serial.begin(9600); pinMode(6, OUTPUT);//connect led to pin 6 }
void loop() { if (Serial.available() > 0) //check for input data {string = "";} while(Serial.available() > 0) { command = ((byte)Serial.read()); if(command == ':') { break; } else { string += command; } delay(3); } if(string == "on")//as "on" is written in android app for turning on led { analogWrite(6, 255); delay(10); Serial.println(string); led = true; } if(string =="off")//as "off" is written in android app for turning on led { analogWrite(6, 0); delay(10); led = false; Serial.println(string); } if ((string.toInt()>=0)&&(string.toInt()<=255)) { if (led==true) { analogWrite(6, string.toInt());//type casting to integer Serial.println(string);//printing the int value delay(10); } } }
STEP 4: Android App
Download the LED Control.apk from link given:
https://drive.google.com/open?id=0B4eY-jcXDOueX0M5...
- Install the app
- upload the code in Arduino (NOTE:keep recieving pin of arduino disconnected while uploading code)
- OPen the app and enjoy controlling LED from mobile
If want to learn Android app code refer...
thank you.
2 Comments
MoisésR24 7 years ago
gracias
DIY Hacks and How Tos 7 years ago
Cool.
