Introduction: Modern Desk Lamp With IPhone Charging Dock
What you need:
- Wooden plank, roughly 50cm (cut in half)
- Plastic board about 1cm thick, I used a chopping board
- Wooden dowel rod (20cm diameter)
- Electrical cable, plug and switch
- 1x Bolt(M10x50mm) + 1x Nut(M10)
- Light fitting and bulb
- Saw and chisel
- Drill with hole saw bits
- Epoxy
- Paint/Varnish depending on your wood and preference.
Wood Contest 2016
Lamps and Lighting Contest 2016
Maker Olympics Contest 2016
2 Comments
5 years ago
Cool lamp design. Do you have any pictures of the creation process?
Reply 5 years ago
Thank you. Unfortunately not, I only found this site after building the lamp. ??
