Modern Radiant Energy Antenna Simple Circuit and Setup
Intro: Modern Radiant Energy Antenna Simple Circuit and Setup
This instructable is intended for learning and experimenting purposes only !
In this instructable I'll show you how to build a simple Tesla-based antenna/radiant energy receiver, and also give a diagram for a simple circuit that can work with it in the exact manner as Tesla explains in his patent.
"Radio Power Will Revolutionize the World" in Modern Mechanics and Inventions (July 1934) " Wikiquote.
STEP 1: Quoting Nichola Tesla
Here is a link to the patent and the quote I have taken from the patent showing in plain English that the antenna plate P needs to be insulated with some kind of insulating material to perform properly.
NIKOLA TESLA.1901
"C is the condenser, P the insulated plate or conducting body, which is exposed to the rays, and P' another plate or conductor, all being joined in series, as shown. The terminals T T' of the condenser are also connected to a circuit"
When trying to understand Nichola Tesla's work it is very important to read in great detail all of the patents and fully understand the meaning of all of his words.
Nikola Tesla patent.
STEP 2: Materials and Tools
Materials Needed:
1 - heavy duty aluminium foil
2 - sharp cutting tool
3 - lamination papers or any other type of insulating material such as glass, a plastic sticker ...
4 - a clothes Iron
STEP 3: Let's Get Started
We need to make sure that the lamination part of the antenna is bigger than the inner metal part of the aluminium to insulate it correctly;
so we shall measure the lamination part and get a slice of aluminium big enough to fit inside the lamination papers.
After we have both of the materials, you will start marking the aluminium foil like in the pictures.
STEP 4: Cutting the Aluminium Foil
Now that you have marked the aluminium foil to the specific size you need, you are ready to cut the right size piece out of that big piece of aluminium foil just like in the pictures.
STEP 5: Getting Ready to Iron It All Together
Now we need to put the aluminium foil inside the lamination papers, Make sure to leave an edge of lamination all the way around the aluminium foil to insulate it completely just like in the pictures.
STEP 6: Iron It All Together
This part is a little tricky. You need to cover your project with a thin towel and iron it together slowly. It takes a little bit of time this way! You need to make sure that you get all of the air out of it. I ironed a wire into my project as well but you don't have to. You can find your own creative way to connect your wire to your antenna plate.
STEP 7: The Circuit to Test the Antenna
Now that you've finished building your own Tesla style antenna plate, you can try and build the following circuit to test the antana plate.
Obviously you can scale this up to any size that you can think of (the bigger the better), using any type of materials and the same principle as this instructable.
The stricter you are with your build, the better results.
Second Part: 'the sircuit'
1 - 4 diodes of any kind (I used RL 207)
2 - a capacitor (I used 200 V - 220 uf)
3 - a soldering iron
31 Comments
Dedededanny 9 years ago
Can anyone explain in detail why plate P should be thinly insulated? Also, the speed of light is roughly 300,000,000 meters/second. Let's just say it's picking up a radio station at around 100mhz. The wavelength here is 3m, so let's use a 3 meter plate. Wouldn't this mean that the bottom could just be receiving a positive charge at the same time the subsequent negative half of the wave hit the top? If this were to happen, why would the positive continue through the circuit to ground rather than to the negative charge at the top which would have a greater voltage difference than ground (or could anyway), and just counteract each other. What I'm trying to ask is if the metal plate could essentially act as a buffer to neutralize the charge before it even has a chance to connect with ground?
sardesai22 2 years ago
AntletherF 5 years ago
Vinyasi 6 years ago
a simulation of AM reception from an aerial powering two inductive loads and recharging a battery...
http://is.gd/aerialpower
KushankS 8 years ago
Temnothorax 7 years ago
If your CAP is high voltage yes. It is not said but the voltage is higher when the plate is far from the ground.For the Zener make sure to have enough resistance in your circuit or use a constant current limiting diode (limit no more than 450 mA).
Be careful!
MarkV156 7 years ago
good !!! enough but more can always
rk samuel 8 years ago
How much volt will I get from this??????
benji.abrams 8 years ago
it really depends on your build, i got 6V in 2 hour of it siting in the room not close to a live AC current.
this is a minimum example of potential only, it is influenced by the electrons in the surroundings.
for example the fact that the antenna ("aluminum foil") is close to the light from the light-bulb and current in the cable that are connected to AC current, it influences the antenna wirelessly with a type of magnetic pulse from the AC current.
it depends on how good you are at tweaking my example ;)
it's wrong !!! the 4 diodes (diode bridge) transvert it from AC to DC !!!
NehemiahM1 8 years ago
Can I use a old TV antenna? Will that work?
yes !! but a longwire or feet dipole from 2x 7,75m working better :P earth is negative above the ground is positive. How higher how more voltage you can made !!! succes 73 de PD0MV
dcipher 7 years ago
What is the purpose of the diodes? I also think your diagram is incorrect because the current will flow right past the capacitor the way it is shown currently.
diode 1n4148 or 1n34a !!!!
73 de PD0MV
Nikjayswal 7 years ago
To low cap !!! 1uF to low realy !! I have made him to cap 16v 1000uF and yes it's work realy good , i can test him realy good in my own created EM field as Licensed Ham Radio Amateur :P my highest voltage 8,5 volt !! 73 de PD0MV
NicoD40 7 years ago
Ät tommy31, yes that fits also.
ArmandoM49 7 years ago
Have you thought about replacing the insulated plate with composite fish scales. The reason why is because they have piezoelectric features that allow them to harvest radiant energy, pressure, sound frequencies.
Brandonoutdoors 7 years ago
alirafiq 8 years ago
