Modify a Dell Laptop Power Supply (PA-10)
Intro: Modify a Dell Laptop Power Supply (PA-10)
Warning: following project is dealing with voltages which are dangerous for human life (110 - 240 Vac)! Please be very careful and start this project only if you have working experience with such dangerous high voltages!
I have a HobbyKing Turnigy Accucel Lithium charger (link) and I needed to feed it with maximum 17 Volt DC. I was missing such power supply. Fortunately I found a genuine Dell power supply for laptops, it was in good condition and was very cheap. Unfortunately it was delivering a fixed 19.5 Volt, but a good amount of current (4.62 Amps).
I searched the Internet for advises on how to modify such power supply, I found nothing about this particular type (PA-10 family from Dell).
So here is a little tutorial of reverse engineering combined with a short guide on how to tackle almost any electronic product you want to modify in case you have no schematic on hand (or if you want to fix it if it is defective).
You will need:
-electronic meter able to measure continuity of printed circuit board (PCB) traces
-internet connection for electronic components data sheet
-paper and pencil
-soldering tools
-Dell PA-10 power supply for laptop
STEP 1: Open the Plastic Case of the Power Supply
First you need to pry open the plastic case of the power supply.
For laptops, these are built as bricks, fully enclosed, sometimes the plastic is welded. You can find various opening methods on the Internet, my choice was to use a red hot knife blade and to cut the contour. This helped to open the case (no pictures, sorry).
Disadvantage: you will make it look bad and the 2 parts will not fit anymore as a tight box.
STEP 2: Identify the Main Functional Electronic Blocks Inside the Device
Now that we have the power supply opened (consider any electronic device), we have to identify the main functional blocks and the type of electronic components.
Given the fact that we know that we are dealing with a switching mode power supply (SMPS), we will go from input side to the output side:
-input side is 110-240 Vac from the AC mains connector
-then are some coils, transistors, capacitors etc dealing with lowering the voltage and changing it from ac to dc (details are on the Internet, SMPS it is an interesting thing to learn about, search flyback SMPS, buck SMPS, boost SMPS)
-feedback block (this one will keep the output voltage fixed and will control the SMPS)
-output side (where the cable is connected and where the identification circuit is located)
As a matter of fact, a SMPS 110-240 Vac to any DC output will have an optical isolation between controlling and drivers and as well slot cut on the PCB - these are easy to be found on our PCB. Therefore between the output side (place where the DC cable is soldered) and the slot cut on the PCB it should be located our feedback block as well.
On that area are 2 small black bugs and we should read the markings on these 2 electronics components: TEA1761 (2 x 4 pins, SO8 SMD) and DS2xzy (2x3 pins, TSOC SMD)
STEP 3: Check the Datasheet of the Electronic Components
We have to find the data sheet of the 2 components found on the previous step: DS2xzy (2x3 pins, TSOC SMD) and TEA1761 (2 x 4 pins, SO8 SMD).
DS2xyz is a one wire memory from Maxim Semi (link). This is not the guy we need, it is a memory used by the laptop to identify the power supply (in case you wonder why the laptop is not working with an HP power supply with the same connector, same parameters etc).
TEA1761 is an integrated circuit "member of the new generation of Synchronous Rectifier (SR)
controller ICs for switched mode power supplies" according to this data sheet.
So TEA1761 is our guy and we need to focus on the electronic parts around this integrated circuit.
In the data sheet / application note is it specified that the circuit is controlling the output voltage of a SMPS by feedback through a voltage divider on pin 5:
STEP 4: Reverse Engineering the Schematic From the PCB
Now that we know so many things about the integrated circuit TEA1761, we have to find the electronic parts on the board itself and to draw the schematic on paper.
We need to use the continuity tester from the multimeter and to draw the schematic on paper. Since the feedback voltage is through a voltage divider and the voltage must be precise over time, I assumed that the voltage divider contains the 2 resistors marked with 4 digits (that means improved tolerance).
So eventually I checked the continuity only on the right side of the TEA1761 and I draw the schematic.
STEP 5: Tweak the Voltage Divider
Now we know which resistors are part of the voltage divider, so we can replace such fixed resistor with a variable one.
I decided to remove from the board R41 (68k Ohm) and to put instead a variable 100k Ohm resistor connected by 2 wires to the board.
Here comes a dangerous part: need to connect the power supply to the mains (110-240 Vac), this time the power supply is opened and live circuit is exposed! Please pay maximum attention during this operation and avoid touching the board of the power supply!
Rotate the variable resistor, this will modify its value, see where the power supply will stop working
(minimum voltage output) and see where the voltage output is 17 Vdc.
Remove the mains from the power supply and continue.
We should desolder carefully the variable resistor and measure its value for an output voltage of 17 Vdc - I measured around 58k Ohm.
I found a resistor of 56k Ohm around and I soldered on the board. The output voltage is 16.5 Volt, good enough.
STEP 6: Close the Plastic Case and Use the Power Supply
I think that the title is self-explanatory :)
I decided to complicate the things: I removed the wire which was going to the laptop and I replace it by a female 5.5mm connector. I had to make an opening on the case, but it is ok.
The case was not willing to close again like it was used to, so I used some cable ties.
Make sure no interior of the power supply is accessible from exterior, this is risky due to the mains voltage inside.
As a conclusion for this Instructable: Internet is giving us a tremendous power, only combined with some neuron 's effort - if you have almost any electronic device, you can try to repurpose it or even fix it if it is broken just by starting from the integrated circuits used inside. Check their functionality, check the small parts around (resistors, capacitors, diodes, inductors etc) and draw a schematic, compare it with the application recommendation from the IC manufacturer and see what can you do from that point on.
Enjoy the electronics! :)
23 Comments
cvdabbeele 6 months ago
- Make sure that the rods are exactly positioned on the seal (use sticky tape)
- Don't squeeze too hard; I have occasionally broken the internal PCBs
/ChriV
PaulA304 2 years ago
АхмедА 4 years ago
Which I liked and the scientific proof
MShafeeq123 5 years ago
CatalinRO 5 years ago
GustavoY2 5 years ago
kingofsteel 5 years ago
thanks.
-I'll search for the voltage divider R41A / R41B, this divider goes from the VOUT (output voltage) and it will feed a fraction of VOUT to pin 2 of TSM103AIW (this output voltage fraction is compared to TSM103AIW internal voltage reference (2.5Vdc)). Red line on the schematic is the path I have to find, I'll use a multimeter and find R41A/ R41B
-after I am sure about which resistor is R41A and which is R41B, I'll remove these 2 resistors and instead of these I'll connect a potentiometer or a variable resistor of 100K, that one should do it
-I'll play with the potentiometer until I'll get the desired voltage (!! do not think that you will have eventually a nice variable voltage source !! - range is limited by the other components around, on my instructable I got from 15Vdc to 19Vdc (PA10))
-after I find the desired voltage, I'll carefully remove the potentiometer and measure both sides of it and I can replace R41A and R41B with the values I measured OR I can glue the potentiometer there and use the PA12 as it is.
Please be very careful when working with the PA12, it is not a toy, can hurt you and kill you, it is connected to mains!!! Energized circuit!!! Be careful, good luck with your mod and hope to hear good news!
BeachsideHank 7 years ago
A heroic effort to be sure, but why not use something like an LM317 and regulate the voltage outside of the power supply? This question is not meant to diminish your useful Instructable either. ☺
edu.gimeno.0 5 years ago
Also a voltage regulator like the LM317 is just the opposite to what
this power supply is doing. These PS have a high efficiency to transform
220V into 19V while dissipating minimum heat. A LM317 will just turn
those 2V (times Amps...) into pure heat and waste the power. By modifyig
a SMPS power supply by fooling the Vcontrol input you keep the high
efficiency aim of this type of devices while adapting the output to your
requirements
CatalinRO 7 years ago
Thanks for your feedback! This effort was mostly on mechanical side, on the electronics was less effort. I think this was the reason: somewhere on the circuit I have only to replace a single resistor without considering the mechanical part of the project. This modified power supply will serve my Lithium charger only and can supply around 4 Amps max, while linear regulators can supply less current, have voltage drop on them, need extra heat sink, need a case too. I used a linear regulator for a bench power supply.
I understand the objective now, thanks. These devices are notoriously compact and well seled, so this was a major acomplishment on your part.
PhabelS 6 years ago
I had tried to re-purpose the same type of charger you have, I salvage this from a pile of electronic junk, I had checked the voltage on cables but there is no voltage, I am wondering if the charger does not works at all or if it is necessary to feed back the one wire memory to cranck up the charger, any thoughts?
marc.deloor.5 7 years ago
Nice workout!
Thank you for your feedback!
