Introduction: Modular Furniture
I wanted a furniture that will fits every room, that will not consume a lot of space ,that can be adjusted and have multi purpose.
so i ended up building 4 block that fit on top of each other....
Measures:
25cm X 25cm X 130cm
Modules:
Keys compartment,
Drawer,
Double shelf ,
Open box
Tools:
saw table, electric screwdriver,
Polishing machine
Step 1: Plan!
First you have to plan your vision and adjust it to your needs, do this step carefully and you will gain lots time and money.
I used cardboard for a little model and SketchUp for 3D model....
Step 2: Measure
After you know exactly what you want, measure you model and multiply it to you needs.
for example: if my model is 2cm X 2cm X 2cm and i want it to be 30cm X 30cm X 30cm, my multiplier is 15.
take all the measures from the model you built times the multiplier, and you are ready for the next step...
Step 3: Precision Is the Name of the Game...
Choose you favorite type of wood,
carefully cut it precisely to your measures.
Step 4: Let the Glue Begin
Now its my favorite part, assemble each of the module piece's together.
use wood glue and screws to attach the parts.
TIP: when you screw a bolt, push a bit further then the surface and then cover the niche with wood glue, after it dries, polish it. this will conceal your screws
Step 5: Polish and Paint
first hand, paint it with wood paint, then polish it to give it the old effect.
optional second hand with either same paint or lacquer, personally i loved it as it came out after the first hand so i left it as is.
Add hooks for keys...
