Introduction: Mojito Recipe in Plexiglass Blue Lighting
I wrote on plexiglass the mojito recipe and then I create a small led circuit that I insered in a frame around plexiglass.
For the mojito recipe I designed it on Photoshop and then I reverted the image in order to write it on the good position on the plexiglass.
It is pretty cheap DIY and it is a low comsuption energy system because you can use 2x 1,5v battery or 3x 1,2v battery.
Step 1: Print Your Model
Print your reverse image and then stick if on plexiglass.
To engrave it I used a dremel with a small peak.
The plexiglass is a 0,5mm thick.
Step 2: Create Your Lighting Frame
I purchase a kind of plastic bar that I could easily cut and clip on plexiglass.
To create the frame, cut 4 bars and then cut in diagonal thanks to a miter box to do the perfect frame.
Step 3: Insert Your LED Circuit in Your Frame
For the circuit, I used 7 LEDs which work between 1,5 and 3,6v which change the light intensity.
I inserted my LEDs in the frame with a small screw driver and then I put the plexiglass.
Step 4: Choose Your Power
You have 3 different choice to powered your lighting frame!!
2x AA 1,5V
3x AA 1,2V
1x transformer at 3V
It is your choice if you want a nomad recipe or a fixed lamp in a bar or anywhere.
Enjoy and Try it !!!
2x AA 1,5V
3x AA 1,2V
