Introduction: Moleskine Pen Clip Mod
With two simple binder clips, you can make a subtle, effective penholder for your favorite Moleskine!
Step 1: Gather Supplies
You'll need two binder clips, each the small kind, one Moleskine or other notebook, and one pen of your choice.
Step 2: Clip
Take your binder clips, open the Moleskine to the back cover, and carefully apply the clips to the cover, right over the pocket. They won't go down far enough to interfere with the pocket. You can place them lower or higher depending on the size of your pen.
Step 3: Clamp
Secure the clips by flipping them over. You can either leave the metal bits there, if you think you'll be removing the clips often, or continue on to the next step.
Step 4: Remove Handles
For a more streamlined look, remove the metal handles by pinching them towards the center. This will draw them out of their holes in the black part. Do this for all four metal clips, and your project is complete. All you have to do now is adjust them depending on how thick your clip is.
Step 5: Add a Pen
Whatever you want. Works best with flat clips. Adjust them slightly so that the pen fits as snugly as possible- you may leave some slack, if you plan to pull the pen out entirely. Or, you can leave the pen cap where it is, and avoid losing it.
11 Comments
13 years ago on Introduction
gel pen over a uniball.
Reply 12 years ago on Introduction
Uniball ink is waterproof when dry, gel ink is not.
I'm not trying to diss you or anything, but I just don't get it. Why not just slip the pen over the flap on the spine rather than have the added encumbrance of the clips.That would seriously be an improvement because its only 2 steps. 1. grab pen and moleskin, 2. slid pens clip over Molskins spine. its also more symmetrical and works on both hard and soft skins versions as well as bigger versions of the moleskin. I have tried with the pen pictured in this instructable which has a bulkier clip than most pens so it should also work with the majority of pans available. I hope ppl find this helpful. Be well, have a blessed life and day, and if you don't find to to be so than take intelligent action and count your blessings again. -Cheers, Peace, Aloha, P.S.- No matter what they say, when the aliens come, they are not the enemy. (the second 'they' is the aliens, the first 'they' is the government) Duuhhhr...
Well, I see two distinct problems with that Idea. The first problem I foresee is by doing that you are adding encouragement for the spine to leave the notebook, by adding extra weight on it, and secondly, unless you have a "Japanese Album" notebook, it is almost impossible to put the pen into that flap on the spine, in all likelihood, unless your notebook is defective, it will have glue in that portion to secure that cloth bookmark to the book. so unless you want to hurt your 15-20 dollar notebook, I would say the method above is the way to go (unless you want to add having a pen/pencil in your pockets at all times) Good Hunting orn310 P.S. - No matter what you say, when the aliens come (With guns), I am going to be hidden, and safe.
Neat!
Wow i love this. Great idea!!!
14 years ago on Introduction
I am so far to cheap to buy a moleskine but use composition notebooks from the dreaded walmart,regular size and the small ones,they now come in PLAIN BLACK!! I do something similar with a bigger binder clip but leave it intact and use it to hold the notebook closed as well as hold my mechanical pencil which I prefer to a pen.Anyway nice instructable definite thumbs up.
15 years ago on Introduction
I like this. Thanks for thinking of it.
Wow... I never expected to have much feedback! Thanks so much, you guys!
Simple and smart! I likey.
I definitely approve of the simple ingenuity.
