Monitorhead: Re-personalising the Pc
Intro: Monitorhead: Re-personalising the Pc
An alternative to email. Inspired by the Glomi style of Marque Cornblatt (check out his short film "Bubble" on http://www.marquecornblatt.com/) and Canti, the robot/space pirate from the anime series Furi Kuri (or Fuli Kuli).
Great for popping over to see some mates.
STEP 1: Items
Defunkt monitor (found in skip) - could also be done with a tv, fishtank or a cardboard box if you are feeling ghetto enough. I could tell the monitor had died because when i picked it up, water came streaming out.
Plastic Coathanger (i swear these things breed in my wardrobe O_o i keep finding more and more of them)
Pipe Insulation (Left behind by a mate when she was making some foam nunchucks for her boyf - possible instructable coming soon)
Bin Bag (found in kitchen)
Random pieces of 1" thick foam (found in a skip too unsuprisingly) - you will need a piece about 50 cm x 10 cm and another about 20 cm square. Its best to just have a big sheet handy and cut to fit... you'll see
Tools:
£8 soldering iron that you aren't too fond of
Things for getting into the monitor - phillips/ flathead screwdrivers, pliers and wire cutters
Scalpel and Stanley knife
Gaffer tape
Something that nearly ressembles common sense
A well ventialted area
Tools:
Gaffer tape
STEP 2: Deconbobulate the Monitor
Take out all the guts (i dont have any photos of this as i did it a couple if weeks beforehand).
There should be a couple of screws hiding behind the fram at the front and some at the back too... check under stickers (NB. this will possibly void your warranty :p)
Once inside proceed to take an insulated screwdriver and touch across ALL the contacts you can see. Make sure you are in no way touching the metal at this time. Also be careful taking out the crt as these things are in a near vacum and have a tendancy to implode when dropped/cracked/blown on, so be very careful.
I kept all the circit board inside as well as the focussing coils for wire usage in other things.
STEP 3: Flame On
Darw an oval on the base of the monitor that is wide enoguh to safely get your head thru. Open all windows and possibly even go as far as to put on a mask
Heat up your soldering iron and poke holes all the way around your oval every half centimetre. Scrape off the excess molten plastic off your soldering iron and then proceed to join up the dots, applying moderate pressure and avoiding your digits.
(In this pic you can also see the holes for the coat hanger pieces and the foam to support your head)
STEP 4: Foamify
Work out how far forward you want your head to be (put it on as a guideline)and then bend the long strip of foam into a headband and secure in place with gaffer.
If the top of your head is uncomfrotable resting on the bare plastic of the monitor in this space then place the other square piece inside of this (you may want to play around with the thickness of this piece using a knife or even carve a shallow depression for your head to fit into)
In the back are two small sections of pipe insulation to support the back of the head. they stick out horrizontally and keep the head in a centralized position. Also on the sides are the pieces of gaffer for keeping the front on (I would find the original screws but they are in a bits box somewhere and I am still only in beta)
STEP 5: Cushion
Open out the pipe insulation and fit it around the rough edges of the hole. This will stay in place by itself but a little gaffer never hurt (apart from when someone sticks in on your hairy arms as a prank - my advice is to go with the grain O_o)
STEP 6: Add Supports
If you try your new headgear on now you may notice it has a tendancy to be nose heavy and dip forwards. To fix this i burnt two holes on the bottom of the monitor roughly in line with my shoulders and then fed the broken halves of a plastic coat hanger through them so they pushed against me and kept the monitor level (see step 3 for a pic of where the holes are)
STEP 7: The Screen
Cut out a rectangular section of plastic bin bag (make sure you have the cheap, near see-thru ones) slightly larger than your screen and then affix to the inside of the front using small pieces of gaffer - if you do the sides in opposing pairs it helps keep the plastic flat and the screen looking wrinkle free (it didn't help enough when i was making tho O_o)
All you need to do now is to replace the front, fixing with tape on the inside (or you could use the original screws to be really picky), stick it on your bonce and then go off and interact with people.
STEP 8: Final Thoughts
I had fun making this and intend to add to it further using some metal shower tubing (found in a skip as well) to link to a backpack and possible forearm gauntlets, attach a VGA or a wall plug on a length of cable (DO NOT WIRE UP THE PLUG - sheesh) and then wander around in a search for power. Either that or put on a suit and become a messaging service for the day, delivering handwritten mail between people on campus. I am also tempted to go to a friend's noise/ambient gig during the next "First Thursday" - college open evening/strangeness on the 1st of march (North Wales School of Art & Design, Regent Street, Wrexham) They have a myspace: http://www.myspace.com/spacebishops
Improvements:
The bin liner is too opaque, i didnt have any fabric at hand but might have to "aquire" some thin black cotton to replace this. Its all very well in bright light as you can make out vague shapes but as i was walking over to a friends house at night... across a busy main road, i decided more clarity was needed.
LED's - some form of emoticon system or a scrolling message board would be great and certainly add a daft punk vibe - the main problem would be if it started to impair vision.
Improvements:
STEP 9: *update* Pics From the Event
Decided to go ahead with the email idea. Replaced the binbag with a sheet of perspex (thanks matt - he found it in a skip) and stuck some frosting on one side - this was the only thing i paid money for - about a fiver for the whole roll.
I had lots of cables and wireage as well as a defunkt wireless keyboard knocking around (guess where they came from) and as there was a hole in the back of the monitor i decided to have lots of trailey cables. As for the keyboard i whited out the keys with stickers and posted vague instructions on them (i.e. write stuff on screen, tell me who it is for and send me on my way) I had a board marker and a wiper on the cables for easy use...
20 Comments
Marble of Doom 15 years ago
lcitron 15 years ago
amdead 15 years ago
firesketch 16 years ago
imonsei 16 years ago
Bigbad2E 17 years ago
http://channel101.com/shows/show.php?show_id=1
TangMu 17 years ago
andresm 17 years ago
maker001 17 years ago
TangMu 17 years ago
sicsick6 17 years ago
Rowen27 17 years ago
FrenchCrawler 17 years ago
TangMu 17 years ago
ongissim 17 years ago
TangMu 17 years ago
