Monkey's Fist Knot AND the Monkey
40,430
65
17
Introduction: Monkey's Fist Knot AND the Monkey
I will show you how to tie a monkey's fist knot, and what you can make with them. I had aways wanted to know how to make these, and one day someone showed me how. They are really fun to make and whack people with.
Step 1: Getting the Supplies
You will need string only. My recommendation is shoestring or pea cord. Make sure it is very long, as in 1 to 2 feet.
Step 2: Starting the Knot
First, wrap the string around your hand 3 times. Make sure it is tight, but not too tight. Next, carefully remove the string from your hand, so it is still coiled up.
Step 3: Tying the Loops Around the Center
Make three loops around the center of the coils, and make them somewhat tight.
Step 4: Tying the Loops Around the Outside
This step is a little tricky, but I took good pictures. Basically tie 3 times around the part that the picture illustrates.The video shows the completed knot undressed. Watch the second video to see it after it's dressed.
Step 5: Dressing the Knot
To dress the knot, basically make it look like a fist by pulling out all of the extra slack. Now you have a monkey's fist of fury!
Step 6: Making the Monkey
To make the monkey, you will need 4 pieces of string. First tie 3 monkey's fists, and leave a lot of slack coming out both ends. Those will be the feet and the head. You can make two more fists for hands if you want. Next, take the extra slack and tie the two legs to the head. Because you cannot make the monkey exactly like mine, you will have to be a bit creative.
Step 7: Tying the Monkey Together
Next, tie a single fisherman's knot around the center for a body. The extra slack of this you can tie off for a tail. If you do not know the single fisherman's, just tie around the center 3 times and pull the string through for the tail. Now you have the body. For the arms, take the leftover string from tying the head to the legs and tie it into the first step in tying the shoelace, or a crossover knot, and pull the arms out going separate ways. If you do not understand some of this, improvise and it will probably still come out well.
Be the First to Share
    • Photography Challenge
    • Anything Goes Contest 2021
    • Jewelry Challenge
      Jewelry Challenge
    17 Comments
    kelsey678
    kelsey678
    8 years ago on Step 7
    Did yours only have one slack line or two? and how did you tie them to the body? This is a cool concept i am just having trouble figuring it out.
    METALBLADE
    METALBLADE
    11 years ago on Introduction
    Here's mine. I wanted to make one so I learned how to make a monkey's fist and it's my first ever monkey's fist project. And it has fists! :)
    Rhonlynn
    Rhonlynn
    12 years ago on Introduction
    I made one,and my monkey does not have fists, either.
    wolfy_9005
    wolfy_9005
    13 years ago on Introduction
    I remember finding one at the park once....a perfectly shaped one about the size of a big fist. My dogs play with it now :)
    tubbychick3n
    tubbychick3n
    why is it that you used monkey's fist knots for everything accept for the monkey's actual fists?
    Tetris1
    Tetris1
    the monkey is awsome but it is very hard to make without any photos
    cubemonkey
    cubemonkey
    14 years ago on Introduction
    I believe someone already did this instructable on his headphones, but the principal is the same. But I was really looking forward to the monkey. Oh, and good pictures.
    mrmucox
    mrmucox
    If you want to make larger Monkey's Fists, you will need to put a spacer in the middle. For example, I like to make mine with 2mm climbing rope, with three turns. A standard marble makes for a great spacer. If you were to use larger rope, you could use a golf ball. Still larger, think mooring ropes, and you can use a baseball. The spacer helps to keep the shape, and keep it from collapsing in on it's self.
    gmjhowe
    gmjhowe
    good, instructable, but i your missing the what to do with them bit. also i was expecting u to show us how to make the monkey. plus the string u have used makes for hard understanding of the knots
