Introduction: Monster Hoods! Keep Warm and Look AWESOME in Cold Weather!
Monsters in the Hood.
I wanted to make Monster Hoods for a while...it just took
a few days of freezing temperatures to motivate me!
Everyone designed their own hoods.
We all got in on the fun!
And, as usual, there's a ton of pictures! Buckle up!
Step 1: Sketch Out Your Idea!
To begin,
I had each of my kids draw a sketch of what they wanted their monster to look like.
My husband said he wanted one too! He sketched up his vision as well!
Step 2: The Supplies!
Then I bought a bunch of fleece!
I spent $15 and made 5 hoods...making them about $3 each. Not bad! I got about 2/3's yard of each hood color.
I was lucky and found the polka dots, red, black and
white fleece in the remnants bin...perfect!
Fleece is wonderful, because it doesn't fray...so there isn't a lot of extra hemming or edging!
You'll need some scraps of colored fleece for decorations! (I got 1/8 yard pieces)
You'll also need some poly fill stuffing
A sewing machine
Embroidery floss or thick thread and a needle for hand-stitching
Felt (we used white for teeth...you could just use fleece)
Snaps (optional)
scissors
Step 3: Basic Pattern
I started with the youngest.
I took a hoodie of his that currently fits to use as the pattern.
Make sure your fleece is folded in half, so when you cut, you are cutting out 2 pieces.
I cut it about an inch or 2 bigger than the hoodie.
They fit loosely and can be worn right over a hoodie!
( I used an adult large hoodie for all the other hoods...for the 8 year old up to adults)
Then cut an identical set out of contrasting fleece...this will be the inside of the hood.
For the adult sized hoods they measured 18" tall and 15" wide.
I got 2/3 a yard of fleece and had some leftovers...good for the decorating!
Step 4: Begin Sewing
Sew around the hood top to the back.
I had my presser foot right on the edge of the fabric, with the needle in the left position.
Step 5: Decorations
Based off the kids sketches...I cut out the shapes for the horns, spikes, eyeballs and accessories.
Cut your fleece about a 1/2 inch larger than you want it to turn
out to make room for seam allowances.
Then sew around the shapes, leaving the bottoms open.
Turn them so the seams are in the inside...or get the kids to come help!
For the cyclops, I knew we needed a large eyeball.
I cut a free hand circle almost as big as my scissors.
I stuffed everything with poly-fil. We had a huge bag full ($7), but barely used any...
I hand stitched with embroidery floss around the outside edge of the circle.
In and out and in and out...the older kids (8 and 10) did their own hand sewing.
Stuff it with "cotton",
Pull it tight and tie it off.
Fabulous eyeball shape. It just needs a felt or fleece pupil hot glued on.
Step 6: Attaching Decorations!
The horns were a bit harder.
After stuffing them I pinned them in place on the hood.
You could just handstitch these on...but I used the sewing machine.
I just lined up my presser foot to the edge of the material
and held the horn while I stitched it slowly.
You can see the inside here...not a perfect circle,
but fine enough for monster horns!
Then I used the same approach for the spikes.
Just pinned them in place and sewed them on!
For the teeth I used white felt.
I sewed it on facing up into the face.
This way after the lining was sewn on, they would poke out.
I did hand sew the eyeballs onto the hoods. Just stitched them on really tight...and tied it off.
It doesn't have to look pretty because the lining will cover it! Yay for lining!
Step 7: Lining!
Okay, now sew your lining of the hood.
You will see I moved my presser foot about 1/4" away from the edge.
This will make the lining a little tighter than the outside of the hood.
Helps it fit nicely together!
Step 8: Sewing Lining Onto Hood!
Now. You want to fit the 2 hood pieces RIGHT sides together.
So I have the freshly sewn hood with the seam exposed on the outside,
and the monster hood with all the accessories shoved inside the lining...
the hideous stitches are all showing.
Then you will sew the 2 hoods together starting the the big stretch that frames the face
(as opposed to the part that sits on the neck)
Just a straight stitch will do the trick!
Step 9: Flipping!
Once you are done with that, you will be able to see down inside the hoods like a bag.
Flip them right side out!
And fit the lining of the hood inside the monster hood.
Then sew a straight stitch across the base of the neck part.
(You could sew this right onto a sweatshirt, t-shirt or robe!)
Oooh! See how perfect!?
Step 10: Snaps to the Rescue!
Then my dashing husband swooped in and saved the day!
He put a snap at the base of the chin! Helps to keep it all in place!
Step 11: Ta Da!
Yes, huge success with the 4 year old!
He loved that his concept became the finished product!
And, no one bothered to wipe his face before our pictures...oops!
Step 12: Do It 4 More Times!!!!
Next was the 10 year olds.
He wanted spikes, a tall horn and red eyes!
We might have made the horn a bit too tall...but it's cool how different his looks!
The spikes were just sewn on flat, and then fluffed up for wear!
They stick up just fine!
Right on with his sketch!
Step 13: Another!
Next was our little girly girly age 8.
She wanted red horns, multicolored spikes and cat eyes with eyelashes!
The spikes were inserted and pinned into the outside of the hood before I sewed the 2 pieces together...
this way they stick up down the back seam.
We added cat-slit pupils and eyelashes
Eyeballs hand-stitched on, the teeth sewn in place and then the lining sewn on!
Cute! We found rainbow fleece for her, so it's a little different than pictured...
but the face is the same!
Step 14: My 3 Little Monsters!
My 3 little monsters!
Step 15: For the Man...
he wanted black with gray horns and one eye. Simple.
Easy! This one went really fast!
Step 16: Me!
My plan changed a dozen times!
I ended up finding this polka dotted fleece, so I went with a simple design...and 3 eyes!
Ta da! I love the blue lining!
And these hoods are so nice and warm!
It was a cold and windy afternoon when we took the pics
and everyone was more than happy to wear their hoods! So fun!
Step 17: Our Little Monster Family!
And there you have it! One fabulous Monster family!
I am thinking I'll use these as Christmas Card photos!
I love how these hoods turned out!
Thanks for sticking out the 17 steps of instructions! (my longest yet!)
Hope you enjoyed it!
Like, really enjoyed it...like on your way to get some fleece to make your own, enjoyed it!
These would be great gifts for little boys...nephews, grandchildren, friends...
Check out my blog doodlecraft for more awesome projects!
And please vote for me in the SEW WARM contest! :)
I'll be your best friend!
First Prize in the
Sew Warm Contest
32 Comments
10 years ago on Step 2
Could you use felt instead of fleece or not? Thanks for posting this awesome instructable i love it!!! :D
Reply 10 years ago on Step 2
Hi,
Fleece is nice because it is warm and slightly stretchy...You could decorate the hood with felt though, but I would do the entire hood out of felt...too scratchy.
Thanks!
Nat :)
10 years ago on Introduction
Not saying i don't like them all there all wonderful it's just your youngest has the cutest one
Ha ha! I just saw this comment! Yes, the youngest one was perfect! His creativity was simple and turned out so cute! I'll be honest and say that my husband wears his the most though! Win-win! Thank you!
No problem i do like ur Husban's i like Black
Marvelous work. And great colors, too!
Thank you! :)
Like your youngest sons one it's very cute
I have been so busy working on the quilt I have not had a chance to stop by to comment on your instructable! The kids did a great job drawing their own characters and everyone are super models! I know this entry will be a winner! You all rock!
Sunshiine
What lucky kids to have such a creative mom! These are so great, using the kids' sketches and making them "come to life"! You might want to offer this service on Etsy.
My thoughts exactly. :)
Thanks! :)
Thanks! That was my first time using a sketch and turning it into something, but it does make we want to do more! Thanks for the encouragement! :)
10 years ago on Step 5
Nice project but could have put DOODLECRAFT 20 times larger, so it seems more like an ad as opposed to an instructable.
but it is a nice idea. thanks for posting
Reply 10 years ago on Step 5
Maybe I will! :) I label all my pictures, especially the ones with my family in them...can't be too careful these days. Thanks!
These are fantastic!! Want to adopt me and make me part of your monster-hood? :)
Yes, consider yourself adopted! :) Welcome to the hood...draw out your monster sketch so we can make you a hoodie too! :) ha ha ha!
SWEET!!! I'm in the hood! ;)
These are great! My nieces and nephews would love them. Oh, I hope I have time to get them done by Xmas.
One caveat: snaps set into fleece don't tend to last. I recommend working out snap position before attaching lining, and including a piece of stabilizing fabric of some sort (I keep scraps of denim and similar fabrics about for this sort of use) that will lie between the layers and is stitched down well.
You are right about the snaps...my husband set them with a piece of leather wedged in between. I should have mentioned...
But there are snap systems that are made for lighter weight fabrics...like for homemade diapers, and I think those would work...?
Thank you!
