Mood Ring Toilet Seat... WHAT?
Intro: Mood Ring Toilet Seat... WHAT?
Making a mood ring toilet seat might be the weirdest project we’ve ever done... but it's Reddit's fault (mostly).
STEP 1: WHY?
We first started thinking about this project when we saw an image of it on Reddit at the subreddit DiWHY. At first you only might wonder... WHY? Just why would you want to make this?.. but then we started wondering... HOW? What would be the best way to make this? Well, there are some pretty standard ways to turn ANYTHING into a "mood ring" like object. Before we get into that though, some background on how thermochromatic crystals work.
STEP 2: HOW?
The liquid crystals we used twist as the temperature changes. At lower temperatures it is non-reflective (black) but as the temperature increases, the light passing through the crystal undergoes Bragg diffraction at the wavelength that has the greatest interference is reflected back, which is perceived as a color by our eyes.
STEP 3: Example
Here is an example of a past project undergoing temperature change. In this case we brought this controller from an air-conditioned room into the sunlight which heated up the controller and bent the crystals through their range of colors.
STEP 4: Find the Correct Object
Start with a black object (preferably shiny/glossy). The smoother the better. If you spray the thermochromatic liquid crystals over white, the effect is almost nonexistent because the white color will always reflect ALL light, instead of just the light that the crystals are reflecting.
STEP 5: Airbrush
Use an airbrush to spray a fine mist of the thermochromatic liquid crystals. We started with the cheapest $9 airbrush we could find... and SEVERELY regretted that. The cheap single action airbrush clogged every 2 minutes or so. We upgraded to a dual action one that cost all of $20!! It was so much better because we were able to open up the nozzle to a larger diameter and it clogged much less and was easier to clean.
STEP 6: Protect
The thermochromatic liquid crystals are suspended in what is basically water and NO adhesives/sealers at all. Just rubbing your finger across the coating will rub it off so you need to protect it. In the past we used an enamel spraypaint but that was NOT durable enough. Maybe we did not use enough coats but something like a 2k high gloss clearcoat (basically a spray epoxy) is much more durable. Just spraying a few coats of that on should be good enough but we wanted to play it safe so we went the extra mile.
STEP 7: Protect (more)
We added RESIN! We love resin. It really smoothed out all the imperfections and left an amazing smooth and durable surface.
And that's pretty much it! Just need to do a quick test to make sure the crystals are still responsive under all that resin!
STEP 8: Test
... annnnnnd it's VERY functional still hahaha. Much more high definition than we imagined.
If you want to see more of our process and the problems we ran into along the way we have a full video available here: https://youtu.be/Aj9SDSAOXf4
17 Comments
mariamabbas010 2 years ago
Emerald04 2 years ago
guidess 3 years ago
winneremerald12 4 years ago
And read all the steps. LOL that gif tho
Rross22 4 years ago
brlittle 4 years ago
NeilRG 4 years ago
dug1000 4 years ago
psyko99 4 years ago
ArtsyEngineering 4 years ago
pawarana 4 years ago
https://www.amazon.com/Solar-Color-Dust-Thermochro...
XanderM7 4 years ago
BlackDidThis 4 years ago
The darn thing gets everywhere! And your equipent may pretty much suffer from this.
Ohtaror 4 years ago
skwilsonwa 4 years ago
wordsnwood 4 years ago
