Motion Sensitive Tesla Coil
Intro: Motion Sensitive Tesla Coil
This year I decided to make my garage into a little haunted house. To add some fun and serious scary points, I wrote some code and hooked up one of my Tesla coils to a motion sensor through my Arduino. It now turns on whenever someone walks by, and it's actually very startling.
STEP 1: Materials
For this, you will need the following things:
- A Tesla coil - $20 - $50
- An Arduino - $35
- A Maxbotix sonar sensor - $25
- One 12V to 120V relay - Free to $6
- One transistor and a resistor to match the relay - Free from old electronics (See this Instrucable for more info.)
- 12V Sealed lead acid battery - Don't you have one already?
- Various wire
STEP 2: Code
Below is the code for the Halloween part of the program. When someone walks by less than 2m away and no one has passed by for 1.5 minutes, the Tesla Coil will turn on.
Also, the code to run the sonar sensor is below.
You can download the sketch below.
int transistor = 13; //transistor base to resistor to pin 13unsigned long time = 0;int avgdistance = 0;void setup(){ Serial.begin(9600); //protip: plug in a serial lcd for quick testing sonarSetup(); pinMode(transistor, OUTPUT); delay(2000); //give time for everything to get ready for(int i = 0; i <= 30; i++) //get an average distance on how far away the other wall is { avgdistance += sonarPulseWidth(); } avgdistance /= 30; avgdistance -= 50;}void loop(){ int distance = sonarPulseWidth(); Serial.println(distance); if(distance < avgdistance && (time + 90000) < millis()) //distance has to be less than the avgdistance away //and can't have been triggered in the past 90 seconds { digitalWrite(transistor, HIGH); delay(500); //turn coil on for 1/2 second digitalWrite(transistor, LOW); time = millis(); }}
//Sonar GND to ground //Sonar +5 to +5 //Sonar TX -- Useless for this project //Sonar RX -- Useless for this project //Sonar AN -- Useless for this projectint sonarPW = 5; //Sonar PW to digital pin 5, 147uS per inch (2.54cm/in) //Sonar BW -- Useless for this projectvoid sonarSetup(){ pinMode(sonarPW, INPUT);}int sonarPulseWidth(){ return ((pulseIn(sonarPW, HIGH) / 147) * 2.54);}
STEP 3: Wiring
The wiring is fairly simple for the sonar sensor, just connect PW (pulse width) output to Arduino pin 5, +5V to Arduino +5, and GND to Arduino ground. For information on how to hook up the transistor and relay, see this Instrucable by gandalfsz for more info on how to do that.
STEP 4: Testing
I was, and still am startled by this thing, and that's while I'm wearing earplugs. Here's me scaring myself silly:
In a few weeks this will go behind a wall of Plexiglas in the soon-to-be haunted house garage.
10 Comments
austin42 10 years ago
nice cat
astral_mage 10 years ago
Thomas Edison 11 years ago
I mean, look into. Yeah, look into.
finfan7 14 years ago
robotguy4 14 years ago
Wouldn't the arduino board be shocked? Perhaps putting it in a Faraday Cage would be a good idea...
DevCoder 14 years ago
cool 14 years ago
guyfrom7up 14 years ago
