Motorized Bicycle Fuel Mixture
Intro: Motorized Bicycle Fuel Mixture
In order to keep your motorized bicycle running well, you need a proper fuel mixture. This will increase the lifespan of all of the parts involved, as well as lubricate certain parts as well. The mixture consists of 2-stroke oil, and 91 octane gasoline. The oil will flow through the same parts as the gasoline, lubricating them along the way. The oil will lubricate the gas tank shutoff valve, the carburetor, and the inside of the engine (the pistons). During the combustion process, a majority of the oil, after lubricating the cylinder, will be burned off. The remainder will run through and drain out of the exhaust.
STEP 1: Gather Materials
Materials Required:
You will need:
A Gas container
A funnel
Gasoline
2-Stroke Oil
And of course a motorized bike.
STEP 2: Purchase Gasoline
This step is fairly simple- head to the gas station and purchase gasoline. 91 octane gasoline is ideal, however, 89 or 87 will work just fine. Before purchasing gasoline, determine how much you will need. The average motorized bicycle kit uses a 1/2 gallon tank, so a gallon will fill up two tanks. The bike also goes 150 mpg, so a gallon should last a fairly long time. Keep in mind that oil deteriorates while it is mixed with gasoline, so only mix the amount of oil you need.
In this demonstration, I will be mixing one gallon of fuel. I will fill up an empty gas container with one gallon of 91 octane gas.
STEP 3: Purchase Oil
Oil is relatively easy to purchase, and inexpensive as well. A trip to your local automotive store will normally yield results- most stores have two stroke oil. The oil I am using is Lucas Oil 2-Stroke oil, which is blue. A majority of 2-stroke oil is blue, however, you will occasionally find other colors.
STEP 4: Determine the Amount of Oil to Mix
The method for determining the amount of oil to mix is simple. A new bicycle, for the first 450 miles (3 tanks of gas) should use a mixture of 16:1- 16 parts gasoline to 1 part oil. A broken-in bicycle will use a 20:1 ratio.
I am using one gallon of fuel. This means that I will need 1/20 of a gallon of 2-stroke oil, which is about 7 oz.
STEP 5: Creating the Mixture
This step, while easy, can be messy. Be sure to do this in a well ventilated area, away from any hazardous ignition sources. You are going to need to pour the necessary amount of oil into your gas container, then mix it up. This can easily be done by using a funnel. Once you have poured the oil in, close the container tightly, then swirl it around to mix the oil. DO NOT put the oil directly into the gas tank and mix it there- this could lead to inconsistency in the mixture, and inject only oil or only gasoline, which would not be good for the bicycle in any case.
STEP 6: Pour in Gas Tank and Use!
Finally, fill up your gas tank to the desired amount. The resulting fuel mixture should look mostly clear, with a slight hint of the color oil you are using. Now, use the bicycle as normal, with confidence that the proper fuel-oil mixture will keep the bicycle running smoothly!
19 Comments
edmistonmark3 3 years ago
Markh14 2 years ago
on the back just make a mental note or these days a note on your phone of how many ounces is in a gallon. Which is 128
What ever ratio you want to know such as 16:1 just divide 128 by 16 which will give u the amount of ounces per gallon this case would be 8 ounces of oil
chriskonsul83 4 years ago
corey.noble 4 years ago
Thresa65 4 years ago
Jackthe15yearoldmechanic 4 years ago
ThomasG221 7 years ago
Is there any reason why 91 octane fuel is better?
TheNecromancer13 6 years ago
20:1 is way too much oil. It will burn dirtier and foul up your spark plugs. I run 24:1 break in and 40:1 after that, and I know people that run 50:1 without any issues.
BobBorq 4 years ago
Now can I just add gas to premixed? Or should I return can and just mix my self?
Thanks sorry for the long drawn out question..lol..
Racin8de 5 years ago
I know opinions differ from just about everyone that owns or maintains a 2 stroke 80cc Chinese Motorized bicycle,however most of these folks recommend 87 octane and NOTHING above.The reason being is 87 octane ignites or a faster flashpoint than the higher Octane fuels.So me being curious decided to pick up a gallon of the 93 Octane which I mix 40 to 1 or about 3 ounces of oil.What a mistake, I could barely get the pig ( 80cc 2 stroke) to start, it ran absolutely horrible. With that said, drained my tank, blew the motor out, fresh tank of 87 Octane and now she rides like the first day I rode it... Just my two cents
TerryH130 5 years ago
acheide 7 years ago
Nice instructions. Some engines like my chain saw use a 50:1 gasoline to oil ratio.
Thanks.
Swansong 7 years ago
Thanks for sharing :)
