Mouse As Door Alarm
Intro: Mouse As Door Alarm
A friend of mine who own a shoes store, since he had some missing articles, asked me a way to monitor the door of the stock.
He just want a cheap system, connected to a pc, which will be able to send emails alarm when the stock door will be open during the days-off.
I decided to hack a old usb mouse and use the existing reed switch as click emulator.
A piece of python on a linux box will detect the mouse click as a open/close door alarm, and send a email.
STEP 1: Prerequisites
You will need :
- a old wired usb mouse
- a linux box using Xorg/X11 (tested on Linux Mint and Ubuntu)
- a reed switch (not on the photo) or a other mecanical switch
- an iron solder
- terminal blocks
- some cables
STEP 2: Hack the Mouse
Open your mouse carrefully, take care about all screws.
Next, identify the mouse buttons. Depending on the mouse, you can have 2 to 5 or 6 buttons.
Next, bypass the button switch. You can desolder the switch or solder directly the cable on the mouse board.
Here, i've decided to solder directly, to be able to reuse the mouse later.
Also, i've only used one switch, but the python script can handle 3 switches.
Once completed, the mouse up and get out the cable to the outside.
Solder the cable to the terminal blocks. These blocks will be used to connect the alarm switch (reed switch or mecanic switch).
STEP 3: Setup Python Script
The python script will do :
- disable the mouse from X11, to prevent bad inputs
- listen mouse events from raw inputs
- detect mouse click (simulate by the alarm switch)
- check if the click occurs during the days-off
- if yes, it sent a email
Before to run the script, you need to edit it, and customize it. All configuration variables are on the beginning.
device_name : the mouse name from X11
xinput_id : the id of mouse from X11
$ xinput list | grep "slave pointer"
Virtual core XTEST pointer id=4 [slave pointer (2)]
SynPS/2 Synaptics TouchPad id=10 [slave pointer (2)]
PS/2 Generic Mouse id=11 [slave pointer (2)]
Kensington Kensington PocketMouse Pro id=13 [slave pointer (2)]
When done, just run the script with sudo, to have read access on mouse raw input.
$ sudo python MyMouseAlarm.py
STEP 4: Connect Your Alarm Sensor
Just connect your alarm sensor to the blocks.
Your sensor should be passive, act as a mecanic switch, it's could be a reed switch, a microswitch, a mercury switch.
Thanks for reading.
Thanks for reading.
4 Comments
Computothought 12 years ago
Sermos 12 years ago
sain3 9 years ago
project is very interesting,but i couldn't understand from where the sound comes and how to interface it with ubuntu.
If some one helps me it would be great.
wistof 9 years ago
Hi,
The interfacing is done by the python script. It don't manage sound alarm yet, but it could be done using pygame lib.
