Introduction: Mouthwatering Cheese/potato Dumplings
Are you looking for an instruction on how to make super easy mouthwatering dumplings? Well, look no more!
Mashed potatoes and few other ingredients combined with some time is all you need to make some delicious dumplings that can also be preserved in freezer for later use.
Student life is not easy. Constant lack of money and time. With frozen cheese/potato dumplings you can have cheap yet very tasty meal in five minutes!
Step 1: Ingredients
Dough:
  • Flour 800-1000 ml
  • Cold milk 125 ml
  • Cold water 125 ml
  • An egg
  • Salt and sugar
  • Vegetable oil 4 tablespoons
To make it healthier you could use e.g rice/cornflour, brown sugar and grey sea salt
Filling:
  • Mashed potatoes
  • Regular cheese
  • Blue cheese
If you do not have leftover mashed potatoes, you can make some.
2 potatoes are enough for this amount of dough.
All you need:
  • Potatoes
  • Milk
  • Butter
  • Onion
Step 2: The Dough
  1. Place 800 ml of flour on a clean table.
  2. Add an egg in the middle.
  3. Mix it while adding all the other ingredients
  4. Add pinch of salt and sugar
The dough will stick to your hands. Just keep mixing. It should come loose eventually. If not, then just add bit more flour.
Instead of wheat flour you could try rice or corn flour.
Let it sit for 45 minutes.
In the meanwhile you could make the mashed potatoes.
  1. Peel two potatoes and cut them into small pieces to make the boiling process go faster.
  2. Also chop one onion and add it to the pot.
  3. Boil until the potatoes are soft.
  4. Drain the water
  5. Mash it!
  6. Add some milk and butter (salt)
Step 3: The Filling
Roll the dough quite thin.
If you do not have a dedicated roller for that then a wine bottle with the labels removed works also.
Use a cup to cut out circular shapes. The bigger the diameter of your cup the bigger the dumplings will be.
Cut cheese into small pieces.
Now it is just up to you which combination you want to make. We added bit of blue cheese to every dumpling which made them super tasty.
Leave the side that has more flour on the outside. Wet the rim of the dough slightly with water. This will help it stick together better. Gently press the dumpling into half moon shape with your fingers.
You could also connect the ends so that the dumpling would form a nice circle.
Step 4: You Are Done!
What´s left now is to find your pot or pan and start cooking.
Or you could lay them in a box and put in deep freezer. They will last long time in there and be always ready to cook.
Serve with sour cream and veggies of your liking!
Bon appetit!
Meal Prep Contest
Second Prize in the
Meal Prep Contest
Leftovers Challenge
Leftovers Challenge
