Multi Drawer Bandsaw Box
Intro: Multi Drawer Bandsaw Box
What i used
1 douglas fir board 1 inch thick and 6 inches wide
1 douglas fir board 1/2 inch thick 6 inch wide
Thickness planer
Sanding grits - 120, 180, 240, 360, 400, 600
sanding sealer
suede tex and glue
wood glue
Spray Lacquer
STEP 1:
For this project i used 2 Douglas fir boards one 1 inch thick and 1 1/2 inch thick both 6 inches wide.
I cut the 1 inch board into 5 x 12 inch sections these will be the top bottom and 3 drawer sections. I also 2 x 12 of the 1/2 inch boards these will go between the draw sections.
I put all the boards though the thickness planer before putting them in the order i wanted them to be placed in box.
STEP 2:
Next i take 3 1 inch drawer boards and draw out the plan for the drawers using a compass for the curved drawers.
The designing of the drawers takes a while if you want to use the space well, but you are free to design any style of draw you wish. I had some square and some oval the oval ones can be pushed or pulled out of the box.
STEP 3:
I then cut all the drawers out leaving the frame for these.
I then glued frame for the drawers in place. After the glue had dried i sanded and used sand sealer before gluing the box together leaving the drawers out .
STEP 4:
I used wood glue and clamps to glue main box together.
The box is now complete time to get the drawers cut.
STEP 5:
Cut the draw front off first.
Then cut base and then the main draw leaving about 1/4 inch outer edge on the drawer. This is shown in more detail in the attached photos and the linked video.
STEP 6:
Now to finish box and drawers using sand sealer 2 coats and sanding with 400 grit after each coat. I then used a spray lacquer to finish.
To finish the inside of the drawer i used saude tex with a matching glue.
STEP 7:
Thats the box all finished.
I hope you enjoyed, if you wish to see the process in more detail please watch the video.
Thank you
29 Comments
johnnymcneill16 2 years ago
It is my hope that they may be able to pass it down for 1 or 2 generations. That is how much I think of this instructable.
I want to make it with materials that will last for a great many years. Does anyone have any suggestions on the type of materials to make this possible? The price is never to high for my two precious girls. Thank you for this instructable from a very greatful grandfather.
WOOd WENCh 3 years ago
RatnaS4 4 years ago
Maker Design Lab 4 years ago
Largrin 4 years ago
bakichmg 5 years ago
Highlandboxes. 4 years ago
seamster 5 years ago
Cliffsclips 5 years ago
Kink Jarfold 5 years ago
keets 5 years ago
razzman 5 years ago
BayRatt 5 years ago
Tweetysvoice 5 years ago
