Multiple Analog Inputs Using One Analoge Pin
Intro: Multiple Analog Inputs Using One Analoge Pin
Hi!
In this instructible I will explain how to read values of more than one sensor by using only one analog input pin.
You might wonder why you want to this.
When you are using a Nodemcu board, as illustrated in the picture, only one ADC pin is availible. For a small weather station I would like to read values of multiple analog sensors: a rain sensor and a light intendsity sensor. This is unfortunately not possible with this board.
A solution is to multiplex the sensors. This works as follows: You will turn a sensor A on, read sensor A, then turn sensor A off. After this you will do the same for sensor B.
The idea is based on the instructable of Breagan. As his code was written in LUA I have writen a sketch in C++. This is handy when you are programming your Nodemcu in IDE (the arduino environment). For ease I tested the sketch and wiring on the arduino UNO/duamilanove.
please see also the intructable where I used this technique!
STEP 1: Wiring
For this project you need the following:
- Two 10K ohm potentiometers;
- Two diodes;
- One 10K ohm resistor;
- Arduino;
- Broadboard;
- Some wires.
Connections:
- Connect one side pin of each potentiometer to ground;
- Connect the other side pin of potentiometer A to pin 10 of the arduino;
- Connect the other side pin of potentiometer B to pin 11 of the arduino;
- Connect the pin in the middle of both potentiometers via a diode to the analog pin 0;
- Add a pull down resistor (10K ohm) between the ground and the analog pin 0.
The potentiometers do have the same characteristics as analog sensors and are easy to use for testing. The diodes are the key for isolating the sensor circuits. Diodes restrict current to only one direction. Without diodes the sensors still work, however they interact with each other.
STEP 2: Coding
In order to multiplex, only one sensor can have a complete circuit at a time. By setting the the GPIO pin 10 to HIGH, we are sending 5v to sensor A and completing the circuit. The other pin (GPIO11) is being set to LOW and is therefor sensor B is turned off.
The sketch will read both values and print a value between 0 and 1023 in the serial monitor. You can open the monitor in the IDE software by pressing CNTRL+M.
As one can see in the illustration above the first potentiometer (A) is fully open while the second one is closed. After this potentiometer A is slowly closed until both values approach zero. After this potentiometer B is fully opened.
Have fun trying this out!
Vincent
34 Comments
Opilite Elixx 3 years ago
vrpsia 4 years ago
I am getting below error message. Pls suggest how to rectify it.
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
Vivek
nusnus 5 years ago
Also as you can see in the example picture from serial monitor the analog values are from 0-908. Lets do the maths: (908/1023)*5 V = 4,44 V. 5 V - 4,44 V = 0,6 V <- diode voltage drop.
This analog multiplexer is a very good idea but you have to consider the physical restrictions when writing the code.
AdunKo 6 years ago
Anumolu Naresh 5 years ago
In that cases use relay to switch the swicth between two potentiometers.
We have multiple analog pins in Arduino use that pins.
Aryw1 6 years ago
AdunKo 6 years ago
Fo2sH828 6 years ago
you really saved my life !!
but node MCU supply 3v , what if a sensor usess 5v ?
NutellaF 6 years ago
Edit, the last technic with only the power supply defeats the purpose of this instructables
You can either have a transistor in a switch configuration to switch higher voltages with only 3.3V (or less) needed to activate, or you take the easier way and buy a 3.3V to 5V step-up converter. What you can also try is just to have an external 5v power supply connected to the sensor and just have the Output wires connected to the nodemcu, but remember to connect ground of the power supply to that of the nodemcu.
nguyendangthienhcmus 6 years ago
A.i'm same ask too. pleasure help me
ReviandiNaufal 6 years ago
if i use other diodes, not the 1A 50V diodes, would it still work?
PatipolT 7 years ago
1. Would it work if I connect the pin in the middle of both analog sensors directly to the analog pin 0 without a diode?
2. Would it be possible to use other resistor rather than 10K ohm for the pull down resistor? What will happen?
Thank you.
CraigT60 6 years ago
Without the diodes you'd have both sensors in the circuit at the same time, and the one powered down could be shorting the output of the other to ground.
PatipolT 6 years ago
Is that means sensor values would be unreliable?
Since diodes have a drop across them that varies by current, for more accurate readings you'd be better off using a multiplexer chip. You can get 8x1 and dual 4x1 multiplexers for a dollar or less.
Raphango 7 years ago
Great ible!
The only problem in using diodes is that you have a voltage drop, so you have to offset this to get a correct read.
BTW, you could add this idea to your ible: Get multiple button presses in a single analog port, like this video:
All the four buttons are linked to a single ATTiny85 AnalogIn, due to the lack of sufficient DigitalIO to the circuit.
Forgot to mention that the different reads are get through different resistor values attached to the buttons.
