DIY Muscle Sensor / EMG Circuit for a Microcontroller
Intro: DIY Muscle Sensor / EMG Circuit for a Microcontroller
This instructable will teach you how to make your own muscle sensor / EMG circuit to incorporate into your next project. Use it to control video games, robot arms, exoskeletons, etc.
Click on the video below for a demonstrations on how to hook up and use your EMG circuit board!
You can now also purchase EMG sensors, kits, cables and electrodes at www.AdvancerTechnologies.com!
Muscle Sensor Kit (now also on SparkFun)
Muscle Sensor Electrodes
Note: This sensor is not intended for use in the diagnosis of disease or other conditions, or in the cure, mitigation treatment, or prevention of disease, in a man or other animals.
About Advancer Technologies
Advancer Technologies is a company devoted to developing innovative game-changing biomedical and biomechanical technologies and applied sciences. Additionally, Advancer Technologies promotes all forms of interest and learning into biomedical technologies. To help culture and educate future great minds and concepts in the field, they frequently post informative instructions on some of their technologies. For more information, please visit www.AdvancerTechnologies.com .
STEP 1: Materials
Click on the links to go to where you can buy items/order free samples.
Circuit Chips
3x TL072 IC Chip - Free Samples
1x INA106 IC Chip - Free Samples
Cables and Electrodes
1x EMG Cables (set of 3)... Note: you could optionally connect the alligator clips directly to the electrodes.
3x EMG Electrodes
Power
2x 9V Battery
2x 9V battery clips
Capacitors
• 2x 1.0 uF Tant
• 1x 0.01 uF Ceramic Disc
• 1x 1.0 uF Ceramic Disc
Resistors
• 3x 150 kOhm 1%
• 2x 1 MOhm 1%
• 2x 80.6 kOhm 1% (Note: You don't need exactly 80.6k resistors. Anything around 80k should suffice. Our MyoWare sensor uses 82k resistors for example.)
• 6x 10 kOhm 1%
• 1x 100 kOhm Trimmer
• 1x 1 kOhm 1%
Misc
• 2x 1N4148 Diode
• Jumper wires
• 3x Alligator clip cables
Optional
• 1x Oscilloscope
• 1x Multimeter
STEP 2: POWER SUPPLY
Now, everyone knows what a positive voltage power supply is, (e.g. common battery) but how do you go about making a negative voltage power supply?
Common electrical circuit rule of thumb is when you connect two batteries in series (eg positive terminal of battery 1 connected to the negative terminal of battery 2) then measure the voltage from the negative terminal of battery 1 and the positive terminal of battery 2, the measured voltage is equal to the summation of the voltages of battery 1 and battery 2.
For this circuit we want a +9V and a -9V power supplies. If we connect our two 9V batteries in series, we will get a power supply of +18V. So how do we get the -9V from these two?
It might help to think about what voltage actually means… voltage is an electrical potential difference. The keyword here is difference. Voltages are only meaningful in terms of the reference point (or more commonly referred to as ground). A voltage is the electrical potential between this reference point and the point you are measuring. Do you see the answer yet?
We do indeed get a +18V voltage reading if we use battery 1’s negative terminal as the reference point… but what if we choose the connection between battery 1’s positive terminal and battery 2’s negative terminal? If we use this point as our reference or ground, then battery 2’s positive terminals voltage will be +9V and battery 1’s negative terminal will be -9V!
Using your breadboard, 9V batteries and battery clips, connect the battery clip wires as shown. However, for the time being, disconnect the positive terminal of battery 2 and the negative terminal of battery 1. It is good practice to always disconnect your power while you assemble a circuit. At the end of the assembly we will reconnect these wires to power the circuit on. (You could also add switches to do this)
STEP 3: SIGNAL ACQUISITION
First, get out your INA106 IC chip (chip A) and insert it into your breadboard as illustrated above. The INA106 is a difference amplifier which will measure and amplify (G=110) the very small voltage differences between the two electrodes you place on your muscle.
Next, grab two 1 M ohm resistors, bend them and then plug them in to your breadboard like the two examples shown. One should connect pins 5 and 6 and the other should bridge pin 1 to your ground rail of your board.
Don’t worry about the other pins of the INA106 for now; we’ll come back to those later.
STEP 4: SIGNAL CONDITIONING - Amplification
Let’s start first with two series of amplification; the first will be inverting amplifier with a gain of -15. An inverting amplifier does exactly what it sounds like. It amplifies your signal but also inverts it. You can find more info about inverting amplifiers here .
We are going to first build an inverting amplifier with a gain of -15. To do this, we’ll need one of the TL072 chips (chip B), one 150 kOhm resistor and a 10 kOhm resistor.
Place chip B as the picture indicates. Now use a jumper wire and connect pin 6 of chip A two rows past pin 8 of chip A. Grab one of the 10 kOhm resistors and plug one pin into this row as well. Connect the other pin to pin 6 of chip B. Bend a 150 kOhm resistor and connect one pin to chip B’s pin 6 and the other to pin 7. You can calculate the gain by G=-R2/R1 or in this case G=-150 kOhm / 10 kOhm. (See image 1)
Next, we are going to add a capacitor to AC couple the signal. AC coupling is useful in removing DC error offset in a signal. Read more about AC and DC coupling here .
Continuing on, we are going to add an active high pass filter to get rid of any DC offset and low frequency noise. To do this you will need two 150 kOhm resistors and a 0.01uF capacitor. Use a jumper wire and the 0.01 uF capacitor to bridge the center gab of your breadboard as shown. (One end of the jumper wire should be connected to pin 7 of chip B). The 150 kOhm resistor will connect the capacitor you just placed to pin 2 of chip B. Now, bend the 150 kOhm resistor and push it into connect pins 1 & 2. (See image 2)
Also, go ahead and connect chip B’s pin 4 to your -9V rail, pin 8 to your +9V rail, and pins 3 & 5 to your GND rail.
STEP 5: SIGNAL CONDITIONING - Rectification
You will need five of the 10 kOhm resistors, both 1N4148 diodes, and a second TL072 chip. Warning… this will be the most difficult phase to assemble! Pay close attention to the pictures!
First, plug in a TL072 chip (chip C) and connect -9V rail to pin 4, the +9V rail to pin 8 and GND to pin 3, as shown in the first image.
Next, place a 10 kOhm resistor (let’s call it resistor A) connecting pin 1 of the TL072 chip from the amplification phase and plug the other end into the row next to the 0.01uF capacitor’s row. Use a jumper wire to connect this row to pin 2 of the second TL072 chip. The next 10 kOhm resistor we’ll call resistor B. Resistor B’s first pin should be plugged into the row where resistor A’s second pin is plugged in and resistor B’s other pin should be plugged into the row two down. Another 10 kOhm resistor’s (resistor C) first pin should be plugged into the row where resistor A’s second pin terminated (same as resistor B) but the other pin should be plugged into the next immediate row over. (See image #2)
Now get out the two 1N4148 diodes. Diodes are polarized so be sure to pay attention what direction you plug them in! We’ll call these diodes A and B. Plug diode A’s positive end (end with black strip) into pin 1 of chip C and plug the negative end into the row of resistor C’s second pin. Get diode B and plug the NEGATIVE end into pin 1 of chip c and plug the POSITIVE end into the row of resistor B’s second pin. (See image #3)
Next, use two jumper wires to bridge the center gap for resistor C and B’s rows. Use another jumper wire to connect the jumper wire’s row connected to resistor B’s row to pin 5 of chip C. Use another 10 kOhm resistor to connect the jumper wire’s row connected to resistor C’s row to pin 6 of chip C. Finally, use the last 10 kOhm resistor to connect chip C’s pins 6 and 7. (See image #4).
Phew… that is for the rectifying phase! Next is the filter phase.
STEP 6: SIGNAL CONDITIONING - Smoothing + Amplification
You will need the last TL072 chip (chip D), the two 80.8 kOhm resistors, the 100 kOhm trimmer, the 1 kOhm resistor and the 1.0 uF ceramic disc capacitor.
First, plug in chip D and connect +9V to pin 8, -9V to pin 4, and GND to pins 3 & 5. (image #1).
Now, grab one of the 80.6 kOhm resistors and connect one end to chip C’s pin 7. Connect the other end to chip D’s pin 6. Next grab the other 80.6 kOhm resistor use it to connect chip D’s pin 6 and 7. Do the same thing for the 1.0 uF capacitor. (image #2)
That’s the end of the filter circuit. However, since this is an active filter, there is a side effect of inverting the signal. We will need to invert the signal one more time (and have the ability to amplify it more if desired) using another inverting amplifier circuit with a trimmer configured as a variable resistor.
Use a jumper wire, connected to chip D’s pin 7, and the 1 kOhm resistor to bridge the board’s center gap. Use another jumper wire and connect the 1 kOhm resistor to chip D’s pin 2. Next, place the trimmer one row over with the pins laid out and a jumper wire connecting two of the pins as pictured. Finally, place the last two jumper wires as indicated. (image #3)
By using a screw driver and turning the trimmer, you will be able to adjust the gain of your signal to account for different signal strengths from different muscle groups. Start out with it set pretty low and go up from there (~20 kOhms).
STEP 7: Circuit Review
If you do not have an oscilloscope handy, go back and review your circuit connections step by step to make sure you have place each component correctly. Pay close attention to the power pins and connections of your chips. If you have these incorrect, you could burn out your chips!
STEP 8: Electrode Cables
Grab a pair of scissors, wire cutters, wire strippers, pocket knife, etc.... basically anything sharp and strip about a 1/4" of the end of the DIN plug on all three cables (the plug end not the snap end).
Next, clip an alligator cable to each of the wires. We will use these to connect the electrode cables to our breadboard with some jumper wire. You could do as I have done and strip the wire and then solder on terminal pins but it is not necessary and the alligator clips will do fine.
STEP 9: Surface Electrodes
After determining which muscle group you want to target (for example I will be using my right bicep) and cleaning the skin thoroughly, place one electrode on your skin above the middle of the length of the desired muscle. Let's call this the mid muscle electrode.
Next, place a second electrode at one end of the muscle. We'll call this the end muscle electrode.
Last, place the third electrode on a bony part of your body nearby the muscle group. We'll call this the reference electrode. For example, for the biceps, I am placing the reference electrode on the bony end of my forearm close to my elbow.
Using the snap connections of the electrode cables, snap each cable to each electrode. Make a mental note of which color cable is attached to which electrode.
STEP 10: Connecting Electrode Cables
Connect the reference electrode to the GND rail of your circuit.
Connect the mid muscle electrode to chip A's pin 2
Connect the end electrode to chip A's pin 3
Lastly, we need to add some circuit protection via capacitors. Tanthium capacitors are polarized like the diodes we used earlier. These are easier to tell which is the positive pin and negative pin since one is always marked with a + sign indicating positive pin. Connect one 1.0 uF tant. capacitor between the +9V rail and GND rail, with the positive end connected to the +9V rail. Connect the other 1.0 uF capacitor to the -9V and GND rails, with the positive end connected to the GND rail.
Now you'll ready to power on your circuit!
STEP 11: Connecting to a Microcontroller
If you've done that check and everything thing looks fine, use jumper wires to connect pin 1 of chip D to an analog input pin of your microcontroller and your GND rail to the GND pin of your microcontroller.
Congratulations you're done!
STEP 12: Arduino Demo
Remember to visit us at www.AdvancerTechnologies.com for kits and fully assembled sensors!
508 Comments
FLIPPtronics 8 years ago
How much do the meterials fot this cost in total? Is it cheaper than the pre-build myoware muscle sensors?
Advancer Technologies 8 years ago
So my two cents is...
deselwa 7 years ago
hello sir
can i use electrolyte 1 uf 50v capacitor instead of tantalum and ceramic disk capacitor because in our country 1 uf tantalum and ceramic disk capacitor are not available.plz sir reply me fast
Advancer Technologies 7 years ago
Yes
RománV1 9 years ago
what programs and code for arduino you used for the data acquisition and the visual representation of the emg signals?, thanks for your time and for your project (:
Advancer Technologies 9 years ago
Salmank 7 months ago
afiqum1095 1 year ago
1) i see your website is down. Can you direct us to another website of yours so that we can refer thoroughly?
2) the coding for arduino is also not in website. Can you please share here? Tq
GusMill33 2 years ago
nilutpalbaruah986 2 years ago
manaswitha2014 2 years ago
nsaisushanth 2 years ago
anonbagel 2 years ago
fettalferiel97 2 years ago
rudiclan 9 years ago
Hello, I have a problem with the circuit. Sometimes everything works fine and sometimes there is no signal. I used a scope to measure each step an figured out that I have a high DC offset after the first ampification step (AD620 with gain of arround 110). The DC offset is about 800 to 1500mV but I see a oscillation when I use the muscle. Now the signal gets amplified by a factor of 15 and the opamp saturates (constant 8,x V). After the ac couple with the capacitor the signal gets zero. Is it possible to reduce the DC offset or decouple the signal before the second amplification step? Thank you!
javeriyad 5 years ago
bhuvan.pancholi94 3 years ago
osamarabeesaadharidy1993 3 years ago
ImRef 3 years ago
I made the circuit for a college project. I would like to thank you for this.
There's a small problem in the circuit, that when i physically touch the ground, the analog read just says 1023 in arduino.I think its getting grounded via the body. If I don't have contact to the ground, it works perfectly.
Can you please help me sort the problem?
