Introduction: Mushroom Necklace
DIY Mushroom Garden Necklace using handmade clay mushrooms and real moss! This tutorial is simple and easy to follow!
Step 1: Stuffing the Moss
This step is when you grab a handful of that moist moss and you need to put it in as gently as possible so nobody gets hurt. Depending on your hand size you can really hurt yourself and other people around you when you put it in.
Step 2: Finishing the Moss
You want to make sure that the moss is secured very tightly in the small jar. Once you get all of the moss in there then its safe for you to put the cork on the tip of the jar.
Step 3: Placing the Mushrooms in the Bottle
This is where it gets tricky, you need to have steady hands. You're going to need to place the tiny mushrooms into the jar very slowly and carefully. When you put it in watch where your putting it and make sure its in the right spot. If you are not good with your hands then you can use tweezers like I did. This is the last step and all you have to do is put the cork in it and wear it!!!
