Mushroom Vitamin D Enhancement
Intro: Mushroom Vitamin D Enhancement
There have been quite a few articles over the past few years suggesting you can create vitamin D in mushrooms by putting them in the sun. I'm always sceptical about super food claims and thought I would do some online research to find the scientific basis of this claim.
My basic findings are this:
- Yes, mushrooms do create vitamin D in the sun
- The amount in a portion of mushrooms (100g) is about the amount suggested as a daily supplement (10 mcg or micrograms)
- You need to expose your mushrooms to direct sunlight or place them under special acrylic plastic that allows UV through
- Your mushrooms should be in the sun for about an hour but no more than two hours
- Cut your mushrooms thin to get the maximum surface area and maximum vitamin D
If you want to try, then these points are all you really need to know, however if you would like to see what I did, then keep reading :-)
Mushrooms contain a chemical called Ergosterol. When exposed to ultraviolet light, a photo-chemical reaction converts the ergosol into Ergocalciferol also known as vitamin D2. Leave the mushrooms in the ultraviolet light too long and the vitamin D2 is reduced as it breaks down.
Sunlight is a natural source of ultraviolet, so exposing your mushrooms to direct sunlight will increase their vitamin D significantly, however placing your mushrooms on an indoor windowsill or in a greenhouse will not work as glass and glass alternatives like plexiglass blocks UV.
There have been some news reports about vitamin D reducing the risk of coronavirus. The published scientific papers I have found contradict each other and the NHS in the UK say there is currently not enough evidence to support this, however they suggest taking 10 micro grams vitamin D a day as it wont hurt and has other health benefits.
I've put a full set of the source documents I used for this instructable at the end, but here are a few of the media articles on the subject:
BBC: Increasing vitamin D in mushrooms
Metro UK: Supercharge your mushrooms
STEP 1: Prepare Your Mushrooms
The first step is to prepare your mushrooms. A portion is normally considered to be about 100g.
I used supermarket button mushrooms and five weighed in at 109g
STEP 2: Slice Your Mushrooms
To get the highest amount of vitamin D in your mushrooms the scientific papers suggest you need to maximise the surface area exposed to the sun, so slice them as thin as you can.
STEP 3: Prepare Your Box
Your sliced mushrooms will need to be spread out on a tray for exposure to the sun. If you want to keep off any flies etc. you will need to cover them, but the cover must allow UV light through. Glass, perspex and most clear acrylic will block UV so you can not use these. There are a couple of specialist acrylics designed to allow UV through that are used in sun beds. Alternatively you can use clingfilm as polyethylene is also transparent to UV :-)
I have designed and made a box specifically for leaving mushrooms in the sun and also to dry them for storage, but you can use any box that can hold your tray of mushrooms.
My box uses sunbed grade acrylic in the lid and is laser cut, has a lid that be placed on it when the optimum amount of sun has been achieved so the mushrooms can be dried and has two holes to allow air flow covered with a mesh to stop insects. I have included the design files as attachments above if you have access to a laser cutter, I also sell them here.
STEP 4: Lay Out Your Mushrooms
Spread out your sliced mushrooms ready to be placed in the sun.
STEP 5: Put Your Mushrooms in the Sun
Your mushrooms need to be exposed to full sunlight for about an hour and no longer than two hours. I set an alarm on my phone to remind me. This should give you about 30 micro grams of vitamin D per 100g.
Tilt the box or tray so it points directly at the sun.
The graph above shows data taken from a scientific paper (see information source 3) and shows the amount of vitamin D that is produced in 100g of sliced mushrooms.
STEP 6: Eat Your Mushrooms
To get the maximum vitamin D from your mushrooms, eat them raw. A quick Google search brought up a good list of raw mushroom salads to try.
Frying mushrooms will reduce the vitamin D content by 15%
Baking them will reduce the vitamin D content by 60%
STEP 7: Information Sources
These are the sources I have used to come up with this instructable.
Mushrooms and UV
3. Dose-Response Effect of Sunlight on Vitamin D2 Production in Agaricus bisporus Mushrooms
Vitamin D and Coronoavirus
4. The role of vitamin D in the prevention of coronavirus disease 2019 infection and mortality
5. Vitamin D: A rapid review of the evidence for treatment or prevention in COVID-19
6. NHS: Recommended Vitamin D amount
Vitamin D and Cooking
4 Comments
ncross1 3 years ago
confuscated1 7 months ago
Thanks in advance!
Orngrimm 3 years ago
mcg? You mean μg (micrograms) propably... Or please explain what mcg's are :)
Also a tip: If you cannot create the μ-sign, just copy it from somewhere like this comment and paste it. Or use the ASCII-Code for it: Press ALT and enter 230 while holding the ALT-key. Upon release of the ALT-Key, the μ should be there. ;)
ncross1 3 years ago
