Introduction: Mushroom Water Fountain
Hi All,
Today I will share how I made this mini mushroom water fountain using 3d printed parts.
Please share your comments
Step 1: What Do We Need ?
- 9W Motor
- Skewer
- 3d Printed parts for the Nozzle
- Download the STL files from https://www.thingiverse.com/thing:4714479
- Print at 0.28mm
- Time: 2hrs
- No Supports needed
- Infill: does not matter
Step 2: Nozzle Assembly
- There are 3 main 3d printed part
- The pipe: Has an inner radius of 14mm to fit a common fish tank pump
- The holders: this holds the cap in place and align to the center
- The Cap: this is what gives shape to the flowing water
Step 3: Configuring the Nozzle
- Place the pump with the nozzle in a deep container
- Pull the cap up by 10 mm
- Switch on the pump and gently push the cap down to achieve the required shape
- If you push the cap very close to the pipe, the water will spill everywhere
- and if the gap is too much, then you will not get mushroom
- it may take few tries to get the balance right
Step 4: Decorate
- Now the have archived the right mushroom effect
- Move the setup into a suitable container, which is a bit deep
- Add stones or marbles
- Switch it on and relax with the soothing sound of the water fountain
Hope you liked this project
Please share your feedback and comments
Items for Future
- Use a powerful motor or scale down based on motor capacity
- Test adding soap to reduce water's surface tension
- Get a decorative bucket for the water pond/tank
