Introduction: Musical Bumpers
This product was created keeping in mind children with visual impairment and Autism but can be enjoyed by any child under the age of 7. The product is a simple product which can be manufactured right at the comfort of your home. However, discretion and professional aid is advised in certain processes. We hope this product brings joy and empowerment to all the children and parents who use this product for their benefit!
Go on to get the instructions on the site or download it through the link given to print it and use it along the journey!
Step 1: Aim of Product
The product aims at solving problems regarding navigation with children who are visually impaired. With our fixpartner being visually impaired and on the autistic spectrum, it makes the product deal with the subject in an even more sensitive manner. It plays with the concept of sound and protection for children of this nature to enjoy themselves while being in a safe and protected environment by themselves.
The product has been designed keeping in mind the type of products designed for kids and their expensive nature. Thus our product has been kept open source and relatively easy to manufacture to increase it’s outreach to the people who need such a product. The manufacture and assembly are quick and the components used are easy to source and modify according to the user’s requirements
There are 2 Bumpers for the cycle or tricycle that the child maybe using
Step 2: Safety Instructions
- Processes like welding should be done under supervision of professionals.
- Gloves should be worn at all times while cutting metal bits to avoid burrs.
- Make sure all sharp edges are filleted to provide extra security for the child.
- Create the product as instructed in the manual for best results.
- Product should not be disconnected very often, to prevent wearing off of the paint.
- Metal edges or the tyres used should be rounded off.
- Paint used should be non toxic and children friendly.
- Toys should be good quality squeaking toys, for longevity.
- Sound checks with the toys should be done beforehand to avoid discomfort.
Step 3: Introduction
Before assembling the Musical Bumpers, separate sub assemblies have to be built and constructed.
The description of every sub assembly in this manual will contain:
• An overview of the needed tools;
• An estimation of the needed time to built the sub assembly; • The steps;
Every step in this manual will be described using the following structure:
• Cautions and warnings (if applicable); • The needed parts; • The actions to perform the step
To make this manual easy to understand, images are used as much as possible.
Step 4: Parts
In this manual, you will read about FRONT bumper and the BACK bumper,.
Step 5: Materials for Front Bumper
1. 1 Tyre - Cut 390 mm Chord from Tyre of Dia.- 420 mm, Thk.-70 mm
2. 3 Squeaky toys - 120 mm to 150 mm
3. 1 Iron Strip - 4 mm x 60 mm x 425 mm + extra mm (for bending)
4. 9 Iron Bits - 4 mm x 20 mm x 30 mm
5. 2 Steel Pipe - 12.5 mm OD x 220 mm
6. 2 Steel Rods - 6 mm OD x 65 mm
7. 4 Pipe Clamps - 23-25 mm
8. 2 Rubber Ends - 70 mm x 70 mm x 40 mm
9. 2 Screws ( Pan Phillips STS) - 25 mm Gauge size 4
Step 6: Time and Tools ( Sub Assembly 1 )
Time - 1 1/2 - 2 hours
Tools -
Circular Bending Machine / Jig
Abrasive Saw
Metal Sander
Gas Metal Arc Welding Machine
Sand Blasting Machine
Pliers
Sanding Paper
Measuring tape
Pen / Pencil
Protractor
Step 7: Step One - Cutting
All the metal parts should be cut and sanded before proceeding with other steps.
* The 45° angles for the metal pipe should be at right angles to each other
* The 25° angle for the metal rod should be only be on one side.
* The metal strip should have some extra length for gripping while bending.
Step 8: Step Two - Bending
Bend the metal strip that has been cut with some extra on a Circular Bending Machine.
* The metal strip should be cut to 425 mm length
Step 9: Step Three - Filleting and Drilling
Fillet the 9 Metal Bits and the Metal Strips. Drill holes in the Metal bits and a slot in the Pipes.
Step 10: Step Four - Welding
1. Insert the 6 mm rods into the slots and weld to the pipe.
2. Weld the Pipe and Rods to the Pipe Clamps.
Step 11:
3. Weld the Connected Pipe structures with connectors to the metal Strip
Step 12:
4. Weld the Metal Bits to the Metal Frame, 4 on top 5 on the bottom.
Step 13: Step Five - Powder Coating
Post finishing the frame send your frame for powder coating to protect it from rusting and also to give it a colour finish. Your frame should look something like this!
The powder coating should be done after you finish the frame for the back bumper as well.
Step 14: Sub-Assembly Two (Front Bumper)
Time - 1/2 hour to 1 hour
Tools -
Miter Saw
Wire Cutter
Drill
Riveter
Brushes
Screwdriver
Step 15: Step One - Cutting
Cut a Tyre with a Miter Saw to a 39 cm Chord from Tyre of Dia.- 42 cm, Thk.-7 cm
Step 16: Step Two - Filleting and Drilling
1. Fillet the ends of the cut tyre to make it safe for the child.
2. Drill 4 mm holes where ever the metal bit’s holes coincide with the tyre. ( 9 holes )
* Most tyres will have a metal wire sticking out which should be removed from the ends .
Step 17: Step Three -
Place toys in the tyre. ( 3 according to measure )
Step 18: Step Four -
Rivet the Tyre to the Frame using Blind Rivets. 9 required.
Step 19: Step Six -
Put in the endings
* Squeeze the Endings to go in only till the end of the tyre and not more.
Step 20: Step Seven -
Screw the Endings to the tyre.
* Prefer screws so that toys can be replaced if required.
Step 21: Step Eight - Painting
Post Assembly Paint the grooves of the tyre or the entire tyre in any colour you want and enjoy! The Paint used should preferably Optilon synthetic rubber or Chlorinated Synthetic Rubber Paint to keep it long lasting!
Step 22: Materials for Back Bumper
1. 1 Tyre Cut 420 mm Chord from Tyre of Dia.- 420 mm, Thk.-70 mm
2. 5 Squeaky toys 120 mm to 150 mm
3. 1 Iron Strip 4 mm x 60 mm x 660 mm + extra mm (for bending)
4. 13 Iron Bits 4 mm x 20 mm x 30 mm
5. 2 Steel Pipe 12.5 mm OD x 240 mm
6. 1 Steel Pipe 12.5 mm OD x 410 mm
7. 3 Pipe Clamps 40-43 mm
8. 2 Rubber Ends 70 mm x 70 mm x 40 mm
9. 2 Screws ( Pan Phillips STS) 25 mm Gauge size 4
10. 13 Blind Rivets 1/4 dia 3.76 - 5.00 mm
Step 23:
Tools -
Abrasive Saw
Metal Sander
Pliers
Sanding Paper
Measuring tape
Pen / Pencil
Protractor
Step 24: Step One - Cutting
* The 45° and 25° cut angles should be at right angles to each other for both set of Pipes
Step 25: Step Two - Bending
* The metal strip should be cut to 660 mm length
Step 26: Step Three - Filleting and Drilling
Step 27:
1. Weld the Pipes to the Pipe Clamps.
Step 28:
2. Welding the Connected Pipes to Bended Metal Strip.
* Make sure the angles align to the Connectors and Metal Strip
* Left to Right 45°, 25°,45° towards the Metal Strip.
Step 29:
3. Weld Metal Bits to Metal Strip at alternate points on both sides. 6 on top 7 on the bottom.
Step 30: Step Five - Powder Coating
Post finishing the frame send your frame for powder coating to protect it from rusting and also to give it a color finish. Your frame should look something like this!
Step 31:
Tools -
Miter Saw Machine / Jig
Wire Cutter
Drill
Riveter
Brushes
Screwdriver
Step 32:
Cut a Tyre with a Miter Saw to a 42 cm Chord from Tyre of Dia.- 42 cm, Thk.-7 cm
Step 33: Step Two - Filleting and Drilling
Step 34: Step Three -
Put in toys in the tyre. ( 5 according to measure )
Step 35: Step Five -
Step 36: Step Six -
Put in the endings
Step 37: Step Seven -
Step 38: Step Eight - Painting
