Introduction: My Nerf Shotgun/rifle Mod
In this instructable you will learn how to make a shotgun/rifle nerf dart. If you make this right, then it will work like a shotgun bullet. If you make it wrong, then it will shoot like a rifle bullet. So....either way you will have fun (I hope).
Step 1: Materials
Okay, now you'll need the materials. these are the stuff you need:
a dart (any kind)
A nerf blaster (I only tested this on the night finder)
a pair of siccors
A screw driver
and a plastic fork
Step 2: Disassembly
Now, you take the dart and pull the rubber tip off. Use the siccors to cut the stem off and push it into the foam tube about 1/4 of an inch.
Step 3: Assembly
Now since you have done all that, you'll have to assemble it in a different way. Take the plastic fork and break the ends off that you eat with. Then, break them in half (I know it's confusing). NOTE: if the stem has a hole in it like the blue tipped darts then stick two of the fork ends in it. The final step is to put the rest of the fork ends in the tube loosely (that means to put about four or five in it).
Step 4: You're Done, Have Fun
You're done, Have Fun!!!
6 Comments
9 years ago on Introduction
you got that right pal!
12 years ago on Introduction
I might have fun but the person I shoot won't.
whats the screw driver for
Reply 12 years ago on Introduction
to push the stem thingy in more unless your fingers are small enough to fit. did yours work?
yes:p
Like did it it the target and exploded, spread the fork pieces imediately, or just went flying and didn't blow up at all.
