My Red Oak Longboard
Intro: My Red Oak Longboard
Decided to make a solid red oak board, needless to say it has NO flex, which I kind of like. It is a solid board and a bit on the heavy side, but it has a really smooth ride. All in all I think it is a great board. Also I did all the work on the board including the pattern, cutting, planing, sanding, staining, etc.
I went with red oak because of the look (I wanted to see a prominent wood grain, and the color of the wood), the lack of flex as flex boards make me very uncomfortable, and durability. As for the pattern on the back I intend to, at one point, paint the inside of the Fleur De Lis gold as I am a saints fan(hence the inspiration of my design).
Wheels are 75mm 80a Orangatang Durians with Redz bearings
Trucks are Randal's 180MM, 50 Deg.
Board is 39.5" long.
14 Comments
ultranewt 11 years ago
smileys 11 years ago
Also finding 1/2 inch thick red oak boards is hard, and pay close attention to the wood grain. If you look at the end of the board you will see the grain, make sure it looks kind of like this:
and not like:
GDADZGSONS 11 years ago
LiftAndLove 11 years ago
Jay-DOG 11 years ago
Ok so since this is my first board (I made some mistakes of course, lol) My widest part of the board is about 1/3 away from tail (not nose... I was totally a begginner when I was making this so that is why I accidently made that mistake)
Anyways I do know how to skate (not an expert lol) I have like a semi-longboard (if that is what you call it). It´s a very fat board and about 33¨...
The board I bought have risers in the trucks as well as notches.
The one I am making now does not have notches so I am just going to get some risers for the trucks... And also I normally have my trucks rather tight than loose so I will be fine with this wheel bite...
And finally, do you recommend me going to a local store to buy a pair of trucks and wheels or to rather buy them online? How big should they be? Like 76 mm? I have seen a large variety of prices but I am looking in the range of $30-60...
Thanks again for answering :)
I am making one right now (my 1st one). I already have the deck cut out, but now I worry about my trucks and wheels.
My deck is very similar to yours. Nose and tail width are about 9 1/2" thick. I am kind of confused on where should I put the trucks. where should I drill? How far from nose and tail? And how wide are trucks normally? Do you think deck is going to touch wheels when I turn?
Please reply and thanks for making this sweet tutorial :)
As for the truck placement, if your board is truly a pin tail like mine (fatter nose skinnier tail) you will want the trucks on the nose closer to the tip of the board as the ones on the tail can be further in.
see this image-
http://2.bp.blogspot.com/_42Ez0bRTcnA/TGDTb0UY45I/AAAAAAAADds/K7mOM-10HTA/s320/pintail_longboard.jpg
As for where to drill, once you have picked out your trucks, go to the truck manufacturer's site and look for drop down/through templates for your trucks, there will be drill hole markings
here is the link to my trucks template IT MAY NOT BE THE SAME FOR YOUR TRUCKS THOUGH!
http://www.randal.com/pdfs/r2template.pdf
Note the drill holes are all you will need to really worry about, unless you make it a drop through.
When you put the trucks on be sure the "king pins" point away from the center of the board, this is very important if you want to turn, which you will.
see,
http://img489.imageshack.us/img489/2236/truckdiagramyg2.jpg
For your last question about the wheels touching your board,
This is a VERY good question, what you are referring to is called "Wheel bite" and can easily cause wipe outs (wheels touch board, board stops, you don't), luckily there are plenty of ways to avoid wheel bite. you can cut notches in your board where the wheels would normally come into contact with the board, and you can add what are called risers. Risers are just little pads you can sandwich in between the trucks and the board thus making the wheels further away from your board.
Also not all boards have have issues with wheel bite(mine for example), and it really only happens when turning sharply, or carving sharply
Also if you are new to long boarding I recommend buying some knee, elbow, and wrist pads for the learning process, for you will most likely have a few wipe outs. I personally had a pretty good one when first learning, and regret not wearing all my safety gear. AND ALWAYS WEAR A HELMET!!!
Penolopy Bulnick 11 years ago
