Introduction: Mystical Backflow Incense Burner
Mystical Backflow incense burner.
Step 1: Introductions
CAW CAW CATION! Make sure you have no paper exposed to the incense. Nothing but metal/foil or things made from non flammable substances should be above, below, or touching the incense.
Step 2: Materials
    Mache clay link: https://www.ultimatepapermache.com/paper-mache-cl...
    • Toilet paper
    • Elmers Glue
    • Flower
    • Joint Compound
    • Water
    • Air tight container
    • Foil
    • Ceramic plate
    • Led candle
    • Masking tape
    • Thick card stock paper
    • Plastic Mirror
    • Crystal ball stand
    • Crystal
    • Incense
    • Bowl/foil bowl
    • Acrylic paint
    Step 3: You No Have Candle?
    Step 4: Pry and Apply.
    Step 5: Mirror Mirror.
    Step 6: Furnishing
    Step 7: I Got Papers?
    I cut the tips in an angle to provide a place for an opening once the foil is wrapped around the tree. You should see this in the next step.
    Step 8: Just the Tip.
    Step 9: Attaching the Tree.
    Its hard to see the holes on the branches, but they are there. Make sure there isn't any foil or tape blocking the holes. Blocked holes means no smoke. The holes are much more visible in the next step.
    Step 10: Spruce-ing Things Up.
    See the holes?
    Step 11: Like a Wet Blanket?
    Please don't forget to remove the candle before you pop it in the oven. The plastic should not melt, but I can't say for sure on the soldered wires inside.
    Step 12: Final Touches.
    There you have it, your own meditation/scrying tree! Once again I would like to apologize for the spelling, and grammatical errors. My bird brain has a fast processor, but chose to store different information in that section of its hard drive hah....Cough. Enjoy and wish me luck!
    Step 13: Behind the Scenes.
    This burner can be made in pretty much any shape or form you desire, I just chose a tree...for obvious reasons. Reminds me of home. Please give this a try, you will be amazed at how useful it is. watching the smoke moving around the crystal and down the tree is beyond hypnotic.
    Paper Contest
    Paper Contest
