SCRAP YARD BAT
Intro: SCRAP YARD BAT
You wont strike out with this light weight custom made bat...found this one at local scrap yard for nothing and turned it into a nice homemade weapon
STEP 1: Gather All of Your Supplies
- light weight aluminum bat
- power drill either electric or battery powered
- 3, 6" long mobile home skirting spikes or long nails
- a drill bit gauge or washers
- a 1/2" drill bit a 1" drill bit
- 1/2 turn locking screws (can get out of shelf or cabinets) and a tap and dye set
- telescoping magnet
STEP 2: Drill Access Hole
Drill a hole in the top first with a 1/2" drill bit then with a 1" step drill bit to make lighter but mainly to be able to access the inside.
STEP 3: Spacing Spikes/nails
Using a drill gauge or washer, measure the diameter of your spikes/nails, and drill holes out using a drill bit one size smaller than the diameter of your spikes/nails. You can space the spikes/nails however you like
STEP 4: Fastening Your Spikes/nails
Since I had no way of welding my spikes on, I found an old shelf and used the 1/2 turn locking screws, I then drilled and tapped 6 of them for use as a nail stop so that the nails will not pull out of my weapon during use. But if you are able to weld it all together, it would be best.
STEP 5: Last But Not Least....
I also made a hanging plaque out of some boards I had laying around. And hand carved a grim reaper above where the bat hangs. That way it will display nicely right next to the man of the house favorite chair...
6 Comments
CalebGreer 7 years ago
This is nasty. I like it.
Cdn Sapper 7 years ago
The carving of the grim reaper is fantastic.
TeresaM7 7 years ago
OMG, that is simply savage! I want one, oh yeah!
h_bender32 7 years ago
Modern Rustic Workshop 7 years ago
DIY Hacks and How Tos 7 years ago
Awesome apocalypse weapon. Melee weapons never run out of ammo.
