NES PAD LED's
Intro: NES PAD LED's
So I've noticed that there's "alot" of people, talking about how they would add LED's to their NES pads, that lights when a button is pressed. Sadly noone seems to do anything about it, but one guy who just added LED's that was on constantly...
So I desided to something about it :-P
Attached: Small video of me demonstarting that it works...
STEP 1: Disassembly
Unsrew the casing, and take out the curcuit board.
STEP 2: Drilling
Deside where you want your LED's, and drill your holes. Use a drill bit that is just as wide as the LED's, so you can just press the LED's in the holes...
STEP 3: Fire Up Your Soldering Iron
1 - Solder a 100 ohm resistor, to the positive pin of the LED.
2 - Solder wires to the LED (pic 1)
3 - Add some hot shrink tubing, and shrink it.. (pic 2)
4 - Make as many as you need.
5 - Add the LED's to your pre-drilled holes, and bend down the pins. (pic 3)
6 - I've done a little "pin out" for for all the buttons. (pic 4)
7 - Solder the nedgative wire of the LED to wichever button you want. (pic 5)
8 - Now solder all the positive wires to the white wire (5V+) on the other side of the curcuit board, and bend them away, so you can close the NES PAD. (pic 6)
Notes:
Allthough the LED only will be lit for a short second, you need atleast an 100 ohm resistor. If you do not use a resistor the LED will draw too much current, and the NES PAD will not be able to send signals to the NES, thus your buttons will not work.
You can add LED's individually to all the buttons, but if you press more than 3 buttons at a time, they might use to much current, for the NES PAD to work properly..
Notes:
STEP 4: And Now My Love, Your Finished
Hook that NES up, and game on :-P
18 Comments
Stegopop 9 years ago
First off I want to thank you for making an instructable that actually has a step by step process. You're the first I've seen on LEDs in Nes controllers that hasn't been lazy about that.
Next I have a question.
If I wanted to put an LED in my Nes controller so that it would light up when you turned the console on, would I need a resistor then as well?
I've pulled a LED out of an broken PS2 controller and thought I'd stick it in my Nes controller but I've never worked with a resistor.
Would it even be necessary in this case?
Thanks a bunch :)
samuraiclinton 14 years ago
Oi23 12 years ago
mrbob1000 17 years ago
denilsonsa 16 years ago
blackcorvo 13 years ago
that means they maybe would not light up with the same brightness if they shared the same resistor...
but you can try it, if you want. this kind of conficuration won't fry your LEDs or anything, and if you google a bit you'll find LED resistor calculators with single LED, parallel LEDs and even series LEDs options. you'll just need to put the source voltage, the voltage you want across the LED and the current going through it.
Hedgerow 15 years ago
zmandudesk8 15 years ago
Brian Henderson 17 years ago
Silas 17 years ago
NetReaper 15 years ago
trsuco 17 years ago
nevermind1534 16 years ago
Neodudeman 16 years ago
Silas 17 years ago
zachninme 17 years ago
TheCheese9921 17 years ago
The3rror 17 years ago
