Introduction: NO BULL MASK
COST $50.00
TIME 2 WEEKS
THINGS NEEDED
1.DUCK TAPE
2.PLASTIC PIPE BENDABLE 4 FEET(HOME DEPOT)
3.CARDBOARD LOTS
4.NEWSPAPER
5.FABRIC YARD 1/2
6.SCREWS10
7.SCREW DRIVER
8.WASHER'S
9.NUTS
10.CLAMPS OR PIPE SETTER (HOME DEPOT)
11.PAPER TOWEL 6 ROLLS(DOLLAR STORE)
12.VELCRO ALOT
TIME 2 WEEKS
THINGS NEEDED
1.DUCK TAPE
3.CARDBOARD LOTS
4.NEWSPAPER
5.FABRIC YARD 1/2
6.SCREWS10
7.SCREW DRIVER
8.WASHER'S
9.NUTS
12.VELCRO ALOT
Step 1: BUILDING a FOUNDATION
OK SO WE FIRST START WITH OUR SIDE CHOPS. YOU NEED TO CUT 2 OF THESE SHAPES OUT AND MAKE THEM A DESENT SIZE. I MADE MINE VERY LARGE IN ORDER FOR ME TO STAND OUT.
Step 2: NEWSPAPER CHEEKS
YOU WANNA BALL UP THE NEWSPAPER UP TO MAKE YOUR CHEEKS. GO AHEAD AND TAPE YOUR CHEEKS TO THE SIDE A AND B'S ROUND PART LIKE SO.
Step 3: BOTTOM AND FRONT FACE
EYE MEASURE DISTANCE BETWEEN SIDE A AND B. PLACE SQUARE BEHIND NOSE AND TAPE. TAPE BOTTOM CHIN TO BOTTOM OF SIDE A AND B.
Step 4: NOSE
TAKE THE NEWSPAPER AND PLACE IN FRONT WHERE THE NOSE WOULD BE.CRUMBLE INTO 2 BALLS AND PLACE. THEN PLACE YOUR CUT NOSE IN FRONT OF NEWSPAPER CRUMBLES AND TAPE DOWN FIRMLY.NOTHING HAS TO BE PERFECT.
Step 5: FOR HEAD IMPLANT
TAPE A PIECE OF CARDBOARD RECTANGLE AND SQUARE ON FOR THE FACE AND FORE HEAD. IT NOW SHOULD LOOK LIKE THE LAST PHOTO.
Step 6: HORNS
THE HORNS ARE EASY. TAKE YOUR PIPE. USE THE PAPERTOWELS AND SLIDE THEM ON THE PLASTIC PIPE. 3 ON EACH PIPE. THERE SHOULD BE SPACE AT ONE END. FOR EACH. NOW CUT AWAY AT THE PAPERTOWELS TO FORM HORNS. LAY YOUR NEWSPAPER OUT AND WRAP THE HORNS WITH THE NEWSPAPER. THIS IS TO PROTECT THE PAPERTOWEL FROM THE DUCKTAPE. NOW TAPE THE ALL OF THE NEWSPAPER DOWN TIGHT. YOU CAN CHOOSE WHAT COLOR FABRIC. IT SHOULD LOOK LIKE THE LAST PHOTO.
Step 7: ATTACH HORNS
NOW THE DIFFICULT PART. YOU SHOULD HAVE THE PLASTIC PIPE WITH SOME AREA NOT COVERED IF YOU DO THEN ITS WRONG. YOU NEED UNCOVERED PIPE. ATTACH THE PLASTIC ARCHES TO THE INSIDE OF THE MASK. YOU WANT TO MAKE THE HORNS FACE THE OPPOSITE WAY WHEN SLID IN THE ARCHS.THE HORNS NEED TO FACE OUTWARD TO THE SIDE.THE SQUARES NEED TO BE COMBINED. I USED SCREWS AND DUCKTAPE. NOW USING THE CARDBOARD SQUARES CUT A HOLE FOR THE SMALL 3 INCH PIPE. PLACE THE PLASTIC POLE IN THE 3INCH PIPE IN THE SQUARE. NOW ATTACH THE CARDBOARD 3 CARDBOARD SQUARES TO THE SIDE OF THE SIDE A AND B AS AN ANCOR FOR THE HORNS.
Step 8: COLOR
NOW YOU HAVE FINISHED PUTTING THE HORNS ON WE CAN COLOR THEM. USING THE 2 FABRIC PIECES YOU HAVE CHOOSE A RIGHT COLOR FOR IT. YOU ARE GOING TO HAVE TO EYE MEASURE THESE. CUT EQUAL LENGTH FABRIC PIECES TO PLACE ON BOTH HORNS.MAKE SURE THE FABRIC IS TIGHT ON THE HORNS. USE THE VELCRO TO HOLD THE FABRIC IN PLACE. IF YOU HAVE HOT GLUE MAKE SURE THE FABRIC CAN'T LEAK.TAKE HORNS BACK OFF
Step 9: PLACE YOUR HEAD
YOU NEED ONE OR TWO PIECES OF SQUARE CARDBOARD. YOU NEED TO PUT THE PIECE OF CARDBOARD ON THE OTHER SIDE OF THE END OF THE PIPE SO ITS NOT POKING YOU IN THE BACK OF THE HEAD.
Step 10: EYES AND EARS
CUT SOME NICE EYES AND EAR SHAPES OUT OF CARBOARD. I USED NEWSPAPER ON THE EARS TO MAKE A BETTER EFFECT.USE THE FABRIC AND VELCRO TO HOLD THE FABRIC TOGETHER.ONCE DONT ATTACH EARS TO SIDE A AND B.EYES COME LATER WHEN HEAD FABRIC IS ON.
Step 11: FACE MASK
NOW GET YOUR LAST FABRIC AND CONSTRUCT AROUND THE HEAD WITH EARS ON. WHEN YOU ARE DONE PLACE HORNS BACK ON AND PLACE EYES ON FACE AS YOU SEE FIT.WITH EVERY THING DONE IT SHOULD LOOK LIKE THIS. NOSE RING IS NOT NEEDED.TOUNGE IS EXTRA TOO
