NOSTALGIC NATURE
Intro: NOSTALGIC NATURE
In this instructable, I'm gonna share how to make a beautiful picture of nature.. a scene which is very nostalgic to me ...
STEP 1: WHAT U NEED....
quilling tool
crimping tool
glue
forcep
pins
various colored strips ( I usually cut it from A4 colored papers)
a circular cardboard
crimping tool
glue
forcep
pins
STEP 2: PREPARATIONS....
cover the cardboard with white paper. ( if u r comfortable u can also paint it with white)
later draw a basic outline of the picture. ( divide the cardboard to make sky, bushes, water n sand)
paint the sky, water and Bushes.
STEP 3: THE BEGINNING...
take a sand colored strip and crimp it using crimping tool.
roll it into a loose coil.
stick those coils on d cardboard to make sand.
STEP 4: MAKING OF BUSH...
To make Bush I have used 3 colors.
make small circles of 2 colors and stick one line of each.
to cover remaining color I have used coils of darker shade.
STEP 5: MAKING OF WATER WAVES...
to make water waves, cut small pieces of different shades of blue color and crumple the pieces...
stick them in d blue region
( dark shade at top)
STEP 6: COCONUT LEAVES..
to make coconut leaves,take a strip of length of vch u wan to make leaves...
then take small pieces of same color and start sticking them on one side ( as shown in figure)
repeat the process for other side...
STEP 7: COCONUT
take a Brown strip and roll it to make a tight coil.
push it frm inside to make a bulge.
u need 2 such pieces.
Join thm together to make a coconut.
STEP 8: BARK OF COCONUT TREE...
roll brown color strip to make a loose coil.
give it a square shape.
make sure u reduce the size of coil as u go up.
STEP 9: WALL OF THE HUT ...
make a small square shaped coil.
and stick them on the black paper taking it as a centre.
(note that black portion Will act as door of the hut)
STEP 10: ROOF OF THE HUT...
to make roof of the hut, place pins on the thermocol as shown in the picture. ( keep in mind that the pins should b in unequal no. )
then take a strip and fix it on the middle pin thn roll it up as shown in the pictures.
repeat the steps to complete the roof.
STEP 11: LEAVES OF TREES...
roll different shades of green color to make leaves.
STEP 12: BARK OF THE TREE..
to make the bark of the tree,
first draw the shape of the tree.
thn make brown colored eye shaped coils.
join them on the paper taking the drawing as a stencil.
keep in mind not to stick them on the paper. at the end u should b able to remove it frm the paper.
STEP 13: ASSEMBLY...
join all the pieces together.
STEP 14: FINAL TOUCH. ..
add crows in the sky.
cut out a boat and stick it on the waves.
cut some fine strips of green color and stick it at the base of the bark of coconut tree in order to make grass.
STEP 15: FINAL LOOK...
the result will b something like this...
2 Comments
nanaverm 7 years ago
Very nice, and I learned some new techniques. Thanks for posting your work.
prasi05 7 years ago
thank u so much and most welcome..
