NRF BLE UART Connection With ESP32-C3 and ESP32-S3
Intro: NRF BLE UART Connection With ESP32-C3 and ESP32-S3
To control a program on an ESP32 this app communicates, via Bluetooth, with a serial monitor app on your mobile phone or tablet. When the here presented program is uploaded in your ESP32 microcontroller you can send and receive text string to control the program.
The example demonstrated here is a simple menu and it shows how to store the data in ESP32 flash storage.
An example using this method is used in a word clock with an ESP32-C3 or S3 and IL3241 display and can be found here: https://ednieuw.home.xs4all.nl/Woordklok/ESP32C3AndMore/ESP32C3ClockAndMoreV.html
STEP 1:
If not already done;
- install the NIMBLE library from the library manager in the Arduino IDE
STEP 2:
- Select your board in the Arduino IDE
STEP 3:
- Select the serial port where the ESP32 is connected to.
- Open the nRF52Menu.ino file and upload it
STEP 4:
If you want to use the serial monitor in the Arduino IDE to control the menu with an ESP32-C3 or esp32-S3 board you may have to change the next in the boards.txt file located here :
c:\Users\ednie\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\boards.txt
2.0.10 is the version number of the board package and can can be different
If you have an S3 board change:
esp32s3.serial.disableDTR=false
esp32s3.serial.disableRTS=false
to -->
esp32s3.serial.disableDTR=true
esp32s3.serial.disableRTS=true
or for an C3 somewhere lower in that boards.txt file
esp32c3.serial.disableDTR=true
esp32c3.serial.disableRTS=true
- Quit and restart the Arduino IDE
- Open the Serial monitor in the Arduino IDE
- Set the baud rate to 115200 ( bottom right of the terminal window)
- Enter i to see the menu
STEP 5:
To connect to the mobile phone (or Ipad, or PC)
- Open the serial monitor app
- Select the ESP32Menu station to connect to.
- Enter i or I to see the menu displayed
The SSID, Password and BLE beacon name are stored in a flash memory
On my Github page or home page you can find many Arduino and ESP32 examples to play with
STEP 6:
The program listing
// ESP32-C3 /S3 Includes defines and initialisations
#include <NimBLEDevice.h> // For BLE communication https://github.com/h2zero/NimBLE-Arduino
#include <Preferences.h>
Preferences FLASHSTOR;
static uint32_t msTick; // Number of millisecond ticks since we last incremented the second counter
// BLE //#include <NimBLEDevice.h>
BLEServer *pServer = NULL;
BLECharacteristic * pTxCharacteristic;
bool deviceConnected = false;
bool oldDeviceConnected = false;
std::string ReceivedMessageBLE;
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
// Common
char sptext[120]; // For common print use
struct EEPROMstorage { // Data storage in EEPROM to maintain them after power loss
char Ssid[30];
char Password[40];
char BLEbroadcastName[30]; // Name of the BLE beacon
byte UseBLELongString = 0; // Send strings longer than 20 bytes per message. Possible in IOS app BLEserial Pro
int Checksum = 0;
} Mem;
// Menu
//0 1 2 3 4
//1234567890123456789012345678901234567890----
char menu[][40] =
"A SSID",
"B Password",
"C BLE beacon name",
"I Print this menu",
"R Reset settings"
// ------------------------------------- End Definitions ---------------------------------------
// ARDUINO Setup
void setup()
Serial.begin(115200); Tekstprintln("Serial started"); // Setup the serial port to 115200 baud //
InitStorage(); Tekstprintln("Setting loaded"); // Load settings from storage and check validity
StartBLEService(); Tekstprintln("BLE started"); // Start BLE service // Print the tekst time in the display
SWversion();
// ARDUINO Loop
void loop()
EverySecondCheck();
CheckDevices();
// Common Check connected input devices
void CheckDevices(void)
CheckBLE(); // Something with BLE to do?
SerialCheck(); // Check serial port every second
// CLOCK Update routine to run something every second
void EverySecondCheck(void)
uint32_t msLeap = millis() - msTick;
if (msLeap >999) // Every second enter the loop
Serial.println(millis());
msTick = millis();
// Common check for serial input
void SerialCheck(void)
String SerialString;
while (Serial.available())
char c = Serial.read(); // Serial.write(c);
if (c>31 && c<128) SerialString += c; // Allow input from Space - Del
else c = 0; // Delete a CR
if (SerialString.length()>0)
ReworkInputString(SerialString+"\n"); // Rework ReworkInputString();
SerialString = "";
// Common common print routines
void Tekstprint(char const *tekst) { if(Serial) Serial.print(tekst); SendMessageBLE(tekst);sptext[0]=0; }
void Tekstprintln(char const *tekst) { sprintf(sptext,"%s\n",tekst); Tekstprint(sptext); }
void TekstSprint(char const *tekst) { printf(tekst); sptext[0]=0;} // printing for Debugging purposes in serial monitor
void TekstSprintln(char const *tekst) { sprintf(sptext,"%s\n",tekst); TekstSprint(sptext); }
// CLOCK Input from Bluetooth or Serial
void ReworkInputString(String InputString)
char ff[50]; InputString.toCharArray(ff,InputString.length()); // Convert a String to char array
sprintf(sptext,"Inputstring: %s Lengte : %d\n", ff,InputString.length()-1);
// Tekstprint(sptext);
if(InputString.length()> 40){Serial.printf("Input string too long (max40)\n"); return;} // If garbage return
sptext[0] = 0; // Empty the sptext string
if(InputString[0] > 31 && InputString[0] <127) // Does the string start with a letter?
switch (InputString[0])
case 'A':
case 'a':
if (InputString.length() >5 )
InputString.substring(1).toCharArray(Mem.Ssid,InputString.length()-1);
sprintf(sptext,"SSID set: %s", Mem.Ssid);
else sprintf(sptext,"**** Length fault. Use between 4 and 30 characters ****");
break;
case 'B':
case 'b':
InputString.substring(1).toCharArray(Mem.Password,InputString.length()-1);
sprintf(sptext,"Password set: %s\n Enter @ to reset ESP32 and connect to WIFI and NTP", Mem.Password);
else sprintf(sptext,"%s,**** Length fault. Use between 4 and 40 characters ****",Mem.Password);
break;
case 'C':
case 'c':
InputString.substring(1).toCharArray(Mem.BLEbroadcastName,InputString.length()-1);
sprintf(sptext,"BLE broadcast name set: %s", Mem.BLEbroadcastName);
break;
case 'I':
case 'i':
SWversion();
break;
case 'R':
case 'r':
if (InputString.length() == 2)
Reset();
sprintf(sptext,"\nReset to default values: Done");
else sprintf(sptext,"**** Length fault. Enter R ****");
break;
default: break;
Tekstprintln(sptext);
StoreStructInFlashMemory();
InputString = "";
// Print Menu and Version info
void SWversion(void)
#define FILENAAM (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
PrintLine(35);
for (uint8_t i = 0; i < sizeof(menu) / sizeof(menu[0]); Tekstprintln(menu[i++]));
sprintf(sptext,"SSID: %s", Mem.Ssid); Tekstprintln(sptext);
// sprintf(sptext,"Password: %s", Mem.Password); Tekstprintln(sptext);
sprintf(sptext,"BLE name: %s", Mem.BLEbroadcastName); Tekstprintln(sptext);
sprintf(sptext,"%s",Mem.UseBLELongString? "FastBLE=On":"FastBLE=Off" ); Tekstprintln(sptext);
sprintf(sptext,"Software: %s",FILENAAM); Tekstprintln(sptext); //VERSION);
PrintLine(35);
void PrintLine(byte Lengte)
for(int n=0; n<Lengte; n++) sptext[n]='_';
sptext[Lengte] = 0;
// BLE
// SendMessage by BLE Slow in packets of 20 chars or fast in one long string.
// Fast can be used in IOS app BLESerial Pro
void SendMessageBLE(std::string Message)
if(deviceConnected)
if (Mem.UseBLELongString) // If Fast transmission is possible
pTxCharacteristic->setValue(Message);
pTxCharacteristic->notify();
delay(10); // Bluetooth stack will go into congestion, if too many packets are sent
else // Packets of max 20 bytes
int parts = (Message.length()/20) + 1;
for(int n=0;n<parts;n++)
pTxCharacteristic->setValue(Message.substr(n*20, 20));
delay(40); // Bluetooth stack will go into congestion, if too many packets are sent
// BLE Start BLE Classes
class MyServerCallbacks: public BLEServerCallbacks
void onConnect(BLEServer* pServer) {deviceConnected = true; };
void onDisconnect(BLEServer* pServer) {deviceConnected = false;}
class MyCallbacks: public BLECharacteristicCallbacks
void onWrite(BLECharacteristic *pCharacteristic)
std::string rxValue = pCharacteristic->getValue();
ReceivedMessageBLE = rxValue + "\n";
// if (rxValue.length() > 0) {for (int i = 0; i < rxValue.length(); i++) printf("%c",rxValue[i]); }
// printf("\n");
// BLE Start BLE Service
void StartBLEService(void)
BLEDevice::init(Mem.BLEbroadcastName); // Create the BLE Device
pServer = BLEDevice::createServer(); // Create the BLE Server
pServer->setCallbacks(new MyServerCallbacks());
BLEService *pService = pServer->createService(SERVICE_UUID); // Create the BLE Service
pTxCharacteristic = // Create a BLE Characteristic
pService->createCharacteristic(CHARACTERISTIC_UUID_TX, NIMBLE_PROPERTY::NOTIFY);
BLECharacteristic * pRxCharacteristic =
pService->createCharacteristic(CHARACTERISTIC_UUID_RX, NIMBLE_PROPERTY::WRITE);
pRxCharacteristic->setCallbacks(new MyCallbacks());
pService->start();
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pServer->start(); // Start the server
pServer->getAdvertising()->start(); // Start advertising
TekstSprint("BLE Waiting a client connection to notify ...\n");
// BLE CheckBLE
void CheckBLE(void)
if(!deviceConnected && oldDeviceConnected) // Disconnecting
delay(300); // Give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // Restart advertising
TekstSprint("Start advertising\n");
oldDeviceConnected = deviceConnected;
if(deviceConnected && !oldDeviceConnected) // Connecting
SWversion();
if(ReceivedMessageBLE.length()>0)
SendMessageBLE(ReceivedMessageBLE);
String BLEtext = ReceivedMessageBLE.c_str();
ReceivedMessageBLE = "";
ReworkInputString(BLEtext);
// Common Init and check contents of EEPROM
void InitStorage(void)
GetStructFromFlashMemory();
if( Mem.Checksum != 25065)
sprintf(sptext,"Checksum (25065) invalid: %d\n Resetting to default values",Mem.Checksum);
Reset(); // If the checksum is NOK the Settings were not set
// COMMON Store mem.struct in FlashStorage or SD
// Preferences.h
void StoreStructInFlashMemory(void)
FLASHSTOR.begin("Mem",false); // delay(100);
FLASHSTOR.putBytes("Mem", &Mem , sizeof(Mem) );
FLASHSTOR.end();
// COMMON Get data from FlashStorage
// Preferences.h
void GetStructFromFlashMemory(void)
FLASHSTOR.begin("Mem", false);
FLASHSTOR.getBytes("Mem", &Mem, sizeof(Mem) );
FLASHSTOR.end();
sprintf(sptext,"Mem.Checksum = %d",Mem.Checksum);Tekstprintln(sptext);
// Common Reset to default settings
void Reset(void)
Mem.Checksum = 25065; //
Mem.UseBLELongString = 0;
strcpy(Mem.Ssid,"MySSID"); // Default SSID
strcpy(Mem.Password,"MyPass"); // Default password
strcpy(Mem.BLEbroadcastName,"ESP32Menu");
Tekstprintln("**** Reset of preferences ****");
StoreStructInFlashMemory(); // Update Mem struct
SWversion(); // Display the version number of the software
