Introduction: Natural Wood Indoor Bicycle Stand for Under $15 USD
I keep my bicycle indoors due to space constraints outdoors. After looking at various manufactured bike stands, I decided to make one that would not look like it belonged in a bike shop rather than in my room. I prefer the look of natural woods and glass, and wanted to match that motif if I could. This bike stand is an easy to create and assemble, attractive indoor wooden bicycle stand that is very stable, yet has a small footprint.
I had some 1 in x 1 in finished scraps in 1 foot lengths, and thought that if I could come up with a way to use it, then I'd feel better about conservation. Mom taught me a lot about how to make every penny count (back in the days when a penny was worth --- well, at least a penny.) These were pretty nice "scraps", and I didn't want them to be wasted. In addition, the 1 foot lengths seemed adequate because I wanted the final bike stand footprint to be small and unobtrusive.
I went through several designs before I settled on this one. I even had the three risers already glued together when I decided that I didn't like what the eventual product might look like, and how easy it would be to use. So I put what I had already made down next to the bike and tried several different approaches to a stand. Because this is a stand for a full-suspension mountain bike, and I regularly swap the road wheels and mountain wheels, I needed to make sure that the stand would clear both sets of wheels.
Step 1: The Materials and Tools.
I used 1 in square x 36 in long ash stock. This stock is available from Home Depot and Lowe's. It is fairly well finished, though for more elegant projects, I further smooth the sides with an orbital sander with 320 grit paper.
Glue: I used Gorilla glue for the first time on this project because of reviews I had read. It requires the wood to be damp before the pieces are glued. We'll see how it survives the test of time.
Clamps: I happened to have a pair of Sears Craftsman 18" clamps on hand. I have also used straps with ratchets and wood blocks or cloth to protect my project. Failing that, you can simply weight the wood pieces while the glue dries.
Angle Braces: I decided to attach two right-angle braces at the end of the stand with the least glued contact surface.
The Wood: I used 12 1-foot pieces in this project. I think that I could have gotten by with 10 pieces. The extra two pieces are there because I changed the design at the last minute. The stepped support consisting of a 12", 8", and 4" piece is built as much for looks as for strength. This wood stock is sold in 3-foot lengths.
Drill and small drill bit (I used a 5/64").
Phillips screwdriver.
Step 2: Preparing the Wood.
Cut wood to the following lengths.
4 - 12"
2 - 8"
2 - 4"
4 - 10.25"
2 - 10.75"
It is important that all cuts are as close to square as possible. The strength of the glue joints will depend on surfaces being flush and smooth where they are glued.
Note that the only dimensions that are specific to the Giant XtC are the 10.25" riser that the suspension rests on and the width of the bike frame at the support point. The other lengths are not critical. In fact, nearly all my wood pieces are shorter than the dimensions listed here. I have listed the dimensions without regard to saw blade kerf - the width of the cut the saw makes through the wood. Cutting a 12" length of wood stock into 4" and 8" pieces results in two pieces that are slightly shorter than 4 and 8 inches. The important dimensions are the height of the bike frame support riser (here 10.25"), the width of the 12" risers that the bike frame sits between, and the length of the base frame end pieces (here 10.75"). The latter dimension is governed by the width of the bike frame where you choose to support it; in my case, the width of the frame at the support point is 6.75", including approximately 0.125" (1/8") of extra clearance to make it easier to slide the bike in and out of the stand.
Sand all cut edges to remove ragged edges and to smooth the cut surfaces prior to gluing.
Step 3: Assembly and Finish.
Assemble the riser clusters first. The Gorilla glue folks recommend dampening the wood that is to be glued. I used a damp sponge. To spread the glue as thinly and as uniformly as possible, I cut the ends off several Q-Tips. The remainder was very much like a lollipop stick, and made an excellent tool for laying down a thin, uniform layer that completely covered the area to be glued. To make sure that I put glue only where it was needed, I put glue on the smaller of the two surfaces to be joined. I let each assembly dry for 2 hours.
If you make a stand similar to mine, you would assemble 4", 8", 12", and 10.25" risers in a row. When that dries, attach the 10.25" frame support riser. Assemble the 12" base pieces to each vertical support assembly. The last step is to attach the base ends.
I varnished the stand in steps. I first put two coats on the base, allowing the first to dry before adding the second. Then I turned the stand upright and applied four coats of varnish to the upper surfaces.
As a final step, I added right-angle braces at the end with the least amount of glued surface area. I pre-drilled the screw holes with a 5/64" bit to make it easier to drive the small screws.
Step 4: Enjoy the Result!
Voila! A bike stand that is at home on my wood floor! Here are close up views of the bike frame resting on the support risers. Note that with the rear wheel off the floor, the bike is supported on three points, two at the rear and the front tire. This makes the stand very stable.
Step 5: Fit for Fatter Tires!
Because I swap wheel sets between my road tires and my off-road tires, I made sure that the stand would allow my fatter off-road tires to clear the frame and the floor when they were mounted on the bike.
Step 6: Bike Stand for 2000 Klein Quantum
Following the theme amd methods above, I created one for my 2000 Klein Quantum, too. Once I had created the first one, the second was easier to visualize, used less wood for the same support, and assembled faster. Note that the support on the RH side would not clear the derailleur at the axle, so I moved it forward. Because the Klein is pretty light, I moved the base frame inside the vertical supports to reduce the total footprint. To protect the Klein's finish, I'll add felt to the top of the support riser.
13 Comments
7 years ago
Question: Do you glue the "sky scrapers" to the base?
11 years ago on Introduction
I like the simplicity of the design. It's small, seems pretty lightweight and the material won't mar the chainstay/frame. I have two bikes in need of a stand and I will probably use your instructible as a starting point. One thing you could do is add felt squares to the wood - where the bike rests on the wood. Just in case for some odd reason the wood begins to splinter a bit. Protect your fingers and your bike.
13 years ago on Introduction
I like this design and will properly try and build one but I intend to use my bike as a power generator (this could be a good way to add friction to the bike) so would be interested to know how to fit a generator to this. Very good work! This is what I have done.
Reply 12 years ago on Introduction
I'm trying to build a stand so I can hook my bike up to a small generator. I was wondering if you would share how you built this and how it works with the generator you have there.
Reply 13 years ago on Introduction
Hi Setithing, I think you have a good idea here. A lot of us would like to make use of the power we waste on our bikes. I think that my design is too fragile to handle the strain of running a generator, though. The bike just sits on my stand, so I don't think that it would power a generator. I have a training bike stand that is all metal, and I think that it could be converted to work with a generator, Your setup here looks sturdy enough to run a generator. I'd recommend slick tires to run more smoothly on the generator shaft. You can actually buy slicks for your bike. I run Specialized Fat Boys. Best of luck with your project. Be sure to post your progress here for all to see!
I am not really in to all the biking this so I don't know much about all the different tires. My main idea was to take the back tyre off and run a drive belt round it but as my back tyre is so worn i could put a wheel on there.
The idea of taking the tire off the rim and running a drive belt sounds interesting. Because your bike is bolted down to the base, that would be good for a drive belt. The trick is to find a belt that would work...
What I did is use the inertube and cut out the valve. It's great because you know what size it is
Nice job Protostar, thanks for posting this up. Hopefully its todays project for me. F2F
14 years ago on Introduction
It seems like you could make this with a lot less wood- the bike sits on only two skyscrapers, but you've built a city. Some simple brackets could replace all that extra wood, and save time.
Reply 14 years ago on Introduction
Hi Shooby, I might be going out on a ledge, but I think this design's intent is to be more sculptural (i.e.'skyscrapers') than utilitarian (i.e. wood and brackets). It's easy to slap on some brackets on to wood and call it a day, but to make it sit pretty sans bicycle is something else. I'd give this one 4.5 stars.
You both have good points. As I mentioned in my original post, I started with one idea and changed it as I went along. Rather than throw away the work that I had done, I just added to it, rotating the vertical riser to accommodate my new design. I didn't want a bunch of metal to clash with the wood. I would have been happy with brass, but most of the brackets I found were zinc and steel, and that didn't fit into my plans. My wife liked the style so much she asked me to make them for the Klein and her Specialized. BTW, Chip, if you think that it's worth a 4.5, you might rate it...
Oh ok, fair enough :) Sorry, I got too into the engineering (and I'm an architect!) I think that aesthetically it's great, I just got caught up in the efficiency of the design once I got thinking about cost reduction. If you build any more of these, I'd recommend elongating the base slightly, so that there's an emphasized contrast between the vertical and horizontal elements. Good project.
