NeckLight : a PCB Necklace for Humans and Dogs
7,035
93
13
Introduction: NeckLight : a PCB Necklace for Humans and Dogs
About: Innovation engineer. Electronic and DIY enthusiast, with personal interests in retro tech, board games and old cars.
Hello everyone, this project is my first Instructables so I will try to do my best.
In this project, I will explain you how I managed to create this PCB necklace that glows in the dark ! To be honest, this is the perfect project if you want to learn about the surface-mount electronics assembly process.
First of all, let me tell you that it was inspired from this project : https://www.instructables.com/id/LED-Jewelry/ made by jiripraus so please, have a look ! When I first tried doing his project I failed terribly and I told myself "Why not use a PCB instead of using straight brass rods ?" So... TADAM this project came to my mind !!!
The initial goal of this project was to make a custom gift to my girlfriend.
On the 3rd picture, you can also see my dog, his name is Baba and I think he is wearing this necklace perfectly ^^ (He looks a little bit like Tony Stark, don't you think ?)
I buy all my stuff from aliexpress, but I'm sure you can find these supplies and tools on other websites.
Required tools
Optional tools
Step 1: Designing the PCB Edge Cut Using Fusion 360
I'm a beginner in CAO but this sketch is pretty easy to do using Fusion 360.
I used the polygon tool and the circular pattern to draw this.
Between picture 1 and 2, I used a tool called Trim for the first time, it helped me cutting the extra lines.
When this was done, I right clicked on the sketch and clicked on "Save as DXF".
Step 2: Making the Schematic and Routing of the PCB Using Kicad
If you want to change the logo inside the PCB, draw your design using Fusion360 or Inkscape and export it as a .dxf file. After that, you can import it on the F.Silks layer on Kicad.
To turn a component footprint differently (either horizontally or vertically), click on the "e" key of your keyboard and point at it at the same time. After that, go to the tab called "Orientation" and specify the angle.
Below, you will find a .rar file gathering three folders. One contains all the pdf layers another contains gerber files and the last one contains the project.
The file you have available here contains some improvements compared to the initial file :
  • I moved all the vias into the pad to make them invisible
  • I moved the R1 footprint because I noticed that it made it harder to remove the battery
If you want to make the same design, just drag and drop all the gerber files on the website of your favorite PCB manufacturer (like JLCPCB or PCBWay). You can keep all the preconfigured parameters if you want but of course you can also change the PCB color.
Step 3: Calculate Values of the Resistors
This is probably the most boring part but it's necessary if you don't want to burn the eyes of people who look at the necklace ^^.
Determining the right luminosity of a particular LED color is pretty experimental.
To calculate the right value of the LED resistor, I used this method :
  • I checked the voltage of the LED using the LED mode of my multimeter (In picture 2 we can see 2.571V for the blue LED)
  • I did the test for the 5 LED colors I had and I determined that taking 2mA was a good value to start with
  • Calculation : R = (Ubat - Uled)/A
    • For the blue LED, this formula gave me R=(3-2.571)/0.002 = 214.5 Ohms, the nearest value I had on my book was 220 Ohms so I picked 220 Ohms (See below for all the colors)
  • I did a test, soldered the resistor to the LED, soldered 2 wires and powered that to the battery. If the luminosity is too strong for you, you can increase the resistor's value, if the light is too dim, decrease the value.
Blue : Uled = 2.571V and R=220 Ohms
White : Uled = 2.614V and R=200 Ohms
Green : Uled = 2.313V and R=360 Ohms
Orange : Uled = 1.887V and R=560 Ohms
Red : Uled = 1.790V and R=620 Ohms
Step 4: Solder the Resistors
Now it's time to solder everything.
Start soldering the 6 resistors. To make things easier you can add some flux if you have some.
If you want a multicolor necklace, don't forget to use the appropriate resistor for the LED.
Step 5: Solder the CR2032 Battery Holder
If you have flux, add it on the 2 pads then place the battery holder and keep it in position by pressing on it with the tweezers.
Step 6: Solder the LEDs
This is the visible side of the PCB so you need to place the LEDs right on their footprints.
The positive voltage is outside the pendant and the negative voltage is inside.
In this case, my LED had one green end which represented the negative voltage.
Step 7: Cleaning the PCB
Once all the soldering steps are done, you need to clean the PCB.
I used some acetone and an old toothbrush to clean. Please wear the appropriate safety equipment to handle acetone.
Step 8: Gift, Wear and Enjoy !
The last step is to insert the CR2032 battery when you want to light up the necklace. If you want to turn off the light, just unplug the battery.
Now feel free to make different pendants, enjoy mixing colors !
Also (and you will find this very convenient), it is now impossible to lose someone -human or animal- in the dark using this flashy necklace. I have tried with Baba chasing a cat and I could follow the whole scene.
If you make your own unique design, I would love to see it so don't forget to share it in comment ^^.
Have a nice day !
PCB Design Challenge
Second Prize in the
1 Person Made This Project!
  • For the Home Contest
  • Big and Small Contest
  • Make It Bridge
    Make It Bridge
13 Comments
HugoM104
HugoM104
2 years ago
Nice work!
I'm trying to do the same project, and I've been having trouble with your files... How an I use gerber files, I just need to modify the silk to a C :P
Help would be appreciated!
Gautchh
Gautchh
Reply 2 years ago
Hi, now in the step 2 you can find the project Kicad in the .rar files. It will be easier for you to make the modifications. I will be glad to see your result.
HugoM104
HugoM104
Reply 2 years ago
Hey! Thank you!
I will post here the result later
Hugo
manudmaker
manudmaker
2 years ago
nice and simple way to add bling to humans and dogs hahaha.
Penolopy Bulnick
Penolopy Bulnick
3 years ago
I just love these! This is my kind of PCB project :D
Gautchh
Gautchh
Reply 3 years ago
Thx you ^^. I will do more of this kind of PCB project soon.
justinetoujourspareil
Amazing necklace, I’ll make mine very soon and shine bright like a diamond
Gautchh
Gautchh
Reply 3 years ago
I would be glab to see it ^^.
kirase
kirase
3 years ago
WOW! I didn't walk throug your whole inst. but still: WOW. You say you'r first inst.?
Can't think of that, I mean, so superb demo of Your work.
Gautchh
Gautchh
Reply 3 years ago
Yeah, it's my first instructables. Thx you for the comment.
PRR5406
PRR5406
3 years ago on Step 8
I'm not being snarky here, but add a GPS signal to it and you have a really innovative way of tracking Grandma when she walks away at the mall, or into the woods. I'm serious about this.
kirase
kirase
Reply 3 years ago
Naah... We are monitoroded much enough as it is?
