Necklace Designs-mothers Day Necklace With the Ingenious Tree of Life Pendant
Intro: Necklace Designs-mothers Day Necklace With the Ingenious Tree of Life Pendant
It is a popular necklace designs on tree of life pendant. You can make the wire wrapped mothers day necklace pendant by following the detailed illustrations and elaborated word explanations.
STEP 1: Things Needed in Mothers Day Necklace:
1mm Aluminum Wire
0.5mm Brass Wire
Piezo Glass Beads- Chips
Brass chain
Side Cutting Plier
Flat Nose Plier
0.5mm Brass Wire
Brass chain
Side Cutting Plier
Flat Nose Plier
STEP 2: Form the Frame
1. Take an aluminum wire segment and then form an oval (in this project) around an object in that shape;
2. Twist the wire ends several turns;
3. Work a loop with one end and wrap the tail around the neck;
4. Take the other wire end and wrap it around the neck in same way.
STEP 3: Work the Tree of Life
1. Cut four 30cm long brass wire strips, fold them in half and separate into three groups as 1-2-1. Attach to the frame by wrapping and twisting;
2. Take the left ends, wrap the rest 6 ends for tree trunk as picture show;
3. Separate the 8 ends again;
4. Slide on the glass chips and secure by wrapping the excess tails around the frame;
5. Then the second wire;
6. Repeat the same processes until complete entire tree of life.
STEP 4: Add on the Chain
Snip a certain long chain and then thread the pendant onto it. Connect the first link and last link by a small jumpring and then it’s a meaningful mothers day necklace at once.
2 Comments
turtledrake 11 years ago
Muhaiminah Faiz 11 years ago
