Nerf Dart Mod
Intro: Nerf Dart Mod
This is how to mod your nerf dart or other darts. To get longer ranges and a more accurate shot
STEP 1: Tools and Pieces You Need
You will need
: wire cutters
: sandpaper
: a pencil
: a nerf or other dart
: wire cutters
: sandpaper
: a pencil
STEP 2: Cut the Front of Your Dart Off
Cut the front of your dart off so that you and put the pencil in the dart tube
STEP 3: Cut the Pencil to the Length of the Dart Tube
Cut the pencil to the length of the dart tube so that it will be flush with the front and back of the dart tube
STEP 4: Sand the End of the Pencil Till It Is Flat
Sand The End Of The Pencil Till It Is Flat, for that it is not sharp
STEP 5: Then Push the Pencil All the Way Through Then Your Done!!!
Push the pencil all the way through then your done and ready to test your new modified dart
STEP 6: Time to Test Your Dart/ What I Will Be Using
I am using my heavily modified nerf jolt that has a heavy compression spring modfied plunger and modded seals and a modified barrel.
Your ranges may differ depending your nerf gun
These are the ranges I got with my nerf gun
: 83ft,87ft,78ft,80ft
So these are the Ranges from 4 shots, from the spot I was standing at
Nerf_ mods and more 8 years ago
