Nerf Jolt
Intro: Nerf Jolt
This Instructable will show you how to make a Nerf Jolt out of K'NEX.
STEP 1: Partz
You will need 8 white connectors, 2 red rods, 2 yellow rods, 4 blue rods, 4 green rods, 1 orange connector, 1 white rod, 5 orange bendy rods, 3 rubber bands, 2 green connectors, 2 yellow , 2 small blue caps, 8 small blue separators, 5 grey separators, 2 black caps, 10 large purple caps, and 2 blue connectors. You also need purple bendy rods (not shown yet) for ammo.
STEP 2: Barrel
Build this piece, then add yellow rods.
STEP 3: Stack
Stack the two blue pieces facing different directions.
STEP 4: Oranges
Add the orange rods, then add two blue rods between them.
STEP 5: Separators
Add the separators and caps to the blue rods as shown. Next, slide down the orange rods.
STEP 6: Yellows
Add the yellow connectors as shown. Make sure that the direction they are going up has the center connection on the top.
STEP 7: Blue Rod
Add a blue rod to the lower end of the yellows.
STEP 8: Connect
Add the orange rod to the top connection. Next, attach the yellows to the yellow rods on the barrel. Next, connect the orange rod to the barrel as shown.
STEP 9: Check
At this point, your gun should look like this.
STEP 10: Trigger
Make two of these pieces and stack them.
STEP 11: Attach Trigger
Insert the trigger, and add a blue rod through it. Add caps and separators to both sides.
STEP 12: Plunger
Make this piece.
STEP 13: Rubber Bands
Attach rubber bands to the trigger as shown.
STEP 14: Plunger Band
Insert the plunger through the hole in the back. Next, add a rubber band.
STEP 15: Loading and Firing
To prime, pull back the plunger AMD press up the trigger. Then load the ammo, and pull the trigger.
STEP 16: Done!!!
You now have a Nerf Jolt! Enjoy!!!
15 Comments
knex_master27 2 years ago
JackDC2000 9 years ago
nerfrocketeer 9 years ago
legoman111 10 years ago
So cool.
nerfrocketeer 10 years ago
The Red Book of Westmarch 11 years ago
nerfrocketeer 11 years ago
TheAwesomestDude 11 years ago
sandroknexmaster 11 years ago
