Nerf Longshot SSR
Intro: Nerf Longshot SSR
ok sorry everyone for having to look at the small pics. ive finally made a better slide show with bigger pictures enjoy!!!!!:):):):):):):)
a nerf mod i did on my longshot that was done on a boring day. it could shoot farther without the barrel but i added the barrel for looks
mods:
AR removal
2 mavrick springs added
plunger padding
vulcan rails added on each side od the gun on the front
recon front barrel attachment
copper barrel extendingfrom inside longshot through recon barrel and out
muzzle added made from recon laser light
distance: 70-80f FT flat about 100 ft angled
for more mods, go to http://nerfmodhq.webs.com/
mods:
AR removal
plunger padding
37 Comments
LeeL70 7 years ago
what spray paints did you use, also how long is the copper tube from the retaliator barrel to the muzzle
warmaster2006 8 years ago
cool
DustySeven7 11 years ago
V1nz0rd 13 years ago
lazyboy13 13 years ago
SaltyNerfer 11 years ago
TheMaker888 13 years ago
i dont have one of these but ill have to get one some time...
anyways yes you could if you had a big enough spring on the Bolt
'it would make it harder to cock'
cause when you pull the bolt back, it has to push the dart into the barrel and it pulls back the plunger 'which loads the gun for shooting'
shadow wave rider 12 years ago
jumpingcat 12 years ago
Glory_Seeker 12 years ago
jliang1 11 years ago
You can get the copper pieces at any hardware store, usually. You're looking for one with an Inner Diameter just larger than the Nerf Dart, although not to long. It should not fall out by itself, but when you give a light puff of air, it should blow out easily. A good idea is to bring along a good dart so you can test the ID of the Barrel. You can prevent it from OXIDIZING ( ;) ) by giving it a light polish with Brass Polish.
Capt. Kidd 12 years ago
knex lord 13 years ago
Paintballer98 13 years ago
