Night Finder to Airsoft
Intro: Night Finder to Airsoft
My friend and I were bored one day, so we decided to make a detachable, sturdy air soft Nerf thing...
SOO... here's what ya need...
-One Nerf Night finder (preferably modded, I added a BB gun spring)
- 2 pins (at least one)
- 2 Rubber Bands
- Scotch Tape
- Air soft BB's
- A Nerf dart (can be a Stefan or old dart)
- Scissors
- Drill (small bit)
- Yellow or longer knex piece (or something you could use as a ramrod)
- TARGET (preferably human, heh heh heh >=D)
This is the harder version, receiver 545 made an easy one
Btw this is my first instructable... and the dates on the pictures are wrong, i made this November 2009.
- 2 Rubber Bands
- Scotch Tape
- Air soft BB's
- Scissors
- Drill (small bit)
STEP 1:
Drill straight through little exposed barrel between blue (or yellow, if you just bought it) parts.
STEP 2:
Cut off end of nerf dart. Tape around the end.
STEP 3:
Insert Nerf tube into barrel. It only works from here on if you take the air restrictors out. Insert taped side in first.
STEP 4:
Stick needles through the hole and the taped Nerf foam, and out the other hole. Do the other needle on the opposite side.
STEP 5:
Stick bb inside the tube. Push it down with knex piece (ramrod). If done right it should stop at the needles. Sorry the picture is the same as step 3. Apparently you can't change the labels.
STEP 6:
Put rubber bands on end. Pull back and fire. <Warning always use eye protection when playing with airsoft.> Now you're done! =D. You can remove this attachment whenever you want.
STEP 7:
Fps Ratings-
Test 1- 143.07
Test 2- 141.14
Test 3- 135.35
Test 4- 137.93
Test 5- 236.63 ?
Average= 158.83
Test 1- 143.07
Test 2- 141.14
Test 3- 135.35
Test 4- 137.93
Test 5- 236.63 ?
Average= 158.83
9 Comments
Air_Assassin 13 years ago
stg.badass 13 years ago
guitarmonk15 13 years ago
MrCrabCakes 14 years ago
yeah i know 14 years ago
KnexFreek 14 years ago
lemonie 14 years ago
L
