Nerf Gun Pistol Mod
Intro: Nerf Gun Pistol Mod
So This is a nerf gun witch I have modded to shoot 9 times as far!!!You all probably know this mod but I was bored so I made an ible on it!!!
This isn't really an amazing mod as everyone probably knows it.
What you will need:
A stretchy elastic band or two.
A nerf gun pistol with a pull back
What you will need:
STEP 1: The Elastic Band
So for this mod you will need an elastic band. You can just use a regular postman band or you could use a thick one like me. If your band aren't long enough then you will need to tie them together.
1-Place the two bands so that they are overlapping each other.
2-Pull the end of the band on the top under the edge of the band on the bottom.
3-pull the end that you have put under the other band back up through the loop and pull tight.
If you don't understand then look at the pictures.
STEP 2: Done!!!
now all that you have to do is loop it around the bottom of the barrel and around the draw back then you are done!!!
#>>>> WARNING <<<<#
If you put to many bands on the drawback can snap!!!
#>>>> WARNING <<<<#
8 Comments
nicdepro 10 years ago
Koob Creations 11 years ago
TheTicklemehellmo 12 years ago
eLeMeNtLtd. 13 years ago
fandr 13 years ago
henster22 13 years ago
knife maker 13 years ago
