Nest (Gen 2) Thermostat With Gas Fireplace (or Other Millivolt System)
Intro: Nest (Gen 2) Thermostat With Gas Fireplace (or Other Millivolt System)
This short tutorial will help you use your Gen 2 Nest thermostat with your gas fireplace or other millivolt type system. I found some other tutorials online but none really seemed to cover everything you'll need so here you go!
STEP 1: Purchase a 24v AC Adapter
Your gas fireplace or other millivolt system does not operate using 24v AC like most HVAC systems. You have to supply the 24v using an external transformer. I got mine at Lowes for $7.99 (item number 168261).
STEP 2: Purchase a Fan Relay
You will need a fan relay. I got mine at Grainger for $9.05 (item number 1N184). The Nest is going to switch the 24v source and activate the control side of this relay which in turn will switch on/off the millivolt system in your gas fireplace.
STEP 3: Install the Nest and Connect the Wiring
First, disconnect the thermostat wires from the gas fireplace -- you will use your existing thermostat wiring -- and it's always a good idea to disconnect things when working with electricity. Install the AC adapter -- I placed mine behind the wall in the laundry room (very convenient there was an outlet right there for me) and ran the wiring up the wall and through the same hole as the thermostat wire.
Connect one lead from the AC adapter to the RH terminal on the Nest backplate (you will probably have to tin the end of the wire so the Nest can sense there is a wire connected), splice the other lead from the AC adapter to the existing RED thermostat wire and finally the WHITE thermostat wire to the W1 terminal on the Nest backplate.
STEP 4: Connect the Relay
Install the relay in or near the gas fireplace. You may need to have some female spade terminals handy for this step if you don't already have them. Put those on all the wires -- two wires from the Nest and the two wires in the fireplace -- first if needed.
Connect your existing thermostat wires from the Nest to terminals 1 and 3 on the relay. Connect the thermostat leads from the fireplace to terminals 2 and 4 on the relay.
STEP 5: Plug in the AC Adapter and Connect the Nest
Plug in the AC adapter. Connect the Nest thermostat to the backplate.
If all is well, you should now have a fully functional Nest thermostat to operate your gas fireplace. It took a while to fully charge the battery in the Nest so that I could configure the WiFi network settings and access the thermostat from the app.
176 Comments
filmil_ 3 years ago
JeredF 1 year ago
With my gas fireplace, this exhibits as the fireplace never turning all the way off when the thermostat is done. This likely also reduces the lifespan of the valve.
msenn77 3 years ago
filmil_ 3 years ago
But if you don't connect 24V AC to the control circuit, then (at least ostensibly) it won't be able to do that. I'll see if I can figure this out safely without trying it on the appliance itself, since my appliance is a propane stove, and I don't want to be sending 24V anywhere near propane gas. (In that respect your relay-actuated design makes a lot of sense!)
sfjava 1 year ago
I think the author suggested mounting the relay inside the heater-unit simply so that the relay could be "hidden" somewhere out of the way; and since that's also perhaps closer to a place where one could also plug-in the 24V adapter/transformer.
Hope that helps! Best, --dk
filmil_ 1 year ago
adambomb2000 1 year ago
Very clear instructions and a lot of helpful comments from folks like 'GG of the North' to help with some of the hookup details.
Much appreciated!
benetoh 1 year ago
msenn77 1 year ago
benetoh 1 year ago
https://www.amazon.com/Transformer-Thermostats-Compatible-Honeywell-Thermostat/dp/B07MT5VWQN?pd_rd_w=vsGOh&content-id=amzn1.sym.3cb9b85f-43ef-4d4b-94d0-0a8efe2194e9&pf_rd_p=3cb9b85f-43ef-4d4b-94d0-0a8efe2194e9&pf_rd_r=YDYA60BRRN3VBQS5FHVD&pd_rd_wg=mRnOB&pd_rd_r=394a383f-f23b-403f-96b5-c59efd4308c7&pd_rd_i=B07MT5VWQN&psc=1&ref_=pd_bap_m_grid_rp_0_1_i
msenn77 1 year ago
** Fine print: I don't have a version of your thermostat to test here so I'm throwing out ideas. Continue at your own peril.
benetoh 1 year ago
I have read other articles suggesting connecting one of the power supply wires to the C. What would the other changes to wiring be for this?
gantho 4 years ago
Wsom 3 years ago
TSchu 2 years ago
sfjava 1 year ago
If you just need to be able to simply "override" the thermostat that you're wiring-in here -- such that if you lose AC power you can still turn on your heater -- then the easiest thing would be to simply wire an "override switch" across the original red/white wires that go to the heater; i.e. across the output of the relay that makes that connection per this project.
Or, if you want a "no-power thermostat control" (instead of just an override "heat on" switch), add a "non-powered" (i.e. millivolt compatible) thermostat right next the "fancy" one -- which can also close the same circuit (but, say, for a given temp). These thermostats usually have an on/off switch as well (or heat/cool/off) -- so that can be set to "off" when you want only the fancy one to control the heater (i.e. most of the time, when you have power).
Hope that helps!
msenn77 3 years ago
terminationshok 3 years ago
amwild66 3 years ago
msenn77 3 years ago
