Netbook & Laptop Stand
Intro: Netbook & Laptop Stand
A simple laptop stand in timber and steel made from cheap materials
STEP 1: Materials & Tools
Materials:
2 large wooden door stops (wedges)
1 metal bracket (see image)
4+ button head wood screws
4+ self adhesive non-slip pads
The metal bracket should be wide enough to provide adequate support for your laptop. This one was about 250mm (10inches) wide. It is important to use button head screws, as countersunk screws will not sit well in a bracket. The non-slip pads need to be thicker than the screw heads to avoid scratching the laptop.
All up this was less than $20AUD
Tools:
Drill
Drill bit
Screwdriver bit
The drill bit should be about the diameter of the screw shaft for hardwood, or about 1/2mm smaller for softwood. The screwdriver bit should match the screw head (e.g Phillips head/crosshead).
That's all. Nice and easy.
Tools:
Drill
Drill bit
Screwdriver bit
STEP 2: Measure Twice, Cut Once
Mark out the position of the screws on the timber. I lined up the holes to make sure each side would be identical. When marking, think about whether horizontal and vertical screws are spaced enough to avoid intersecting.
When looking at placement of the screws, consider where you will place the pads (step 4). As it will probably be best to have the pads as close to the corners as possible, you may want to position the screws further down from the top.
STEP 3: Screw It
Drill holes in the timber. Make sure you drill perpendicular to the surface you are drilling, or the screws will not sit straight against the bracket.
Affix the bracket to the timber using the screwdriver bit. Make sure you don't strip the screw head (especially in hard wood). If the screw won't go without jumping, try re-drilling 1/2mm / one gauge larger.
STEP 4: Padding
Stick on the adhesive pads. I might have used a few too many here, for a nicer look try one at each corner.
If you have a particular laptop you want to use it with, make sure the pads aren't going to obstruct the airflow.
STEP 5: Done
Your laptop should sit nicely on the pads without scraping on the screws. If the laptop is large, make sure you move it down the stand so it doesn't overbalance backwards.
There should be plenty of room for at least the normal airflow around the base of the laptop, and the steel bracket will allow you to easily add a fan, and keep it out of site.
The laptop now sits at a better angle for typing, and moves the screen up about 400mm (~2 inches) for easier viewing.
Enjoy.
Enjoy.
26 Comments
MRedu 12 years ago
thewarp16 14 years ago
i made mine with 2 squares of 10mm board then drill a lot of holes were the speakers and fan was then in between the boards i put corner bits.
good to see you didnt just buy some cheep laptop stand =]
5 outa 5
mbudde 14 years ago
joshedmonds 14 years ago
mbudde 14 years ago
mbudde 14 years ago
macobt 14 years ago
amakerguy 14 years ago
DrCoolSanta 14 years ago
giantoz 14 years ago
booth.derek 14 years ago
ThinkBeforeYouSpeak 14 years ago
