Introduction: New Casing From Lego Brick
My old tiny pendrive stopped opening. It's time to give it second life.
This time I decided to use glue gun. There is no blinking led and the Lego Brick is very tiny. I decided to use red 2x1 red brick which is easy available. You will also need small flat screwdriver and sharp knife.
Step 1: ABC... Done
A. I removed pendrive from old case. It was easy because there where no screw, glue or something like that. I was enough to press a screwdriver into the slot and eject the disk.
B. Most scary part ;) I need to cut plastic back to fit the case. Watch your fingers!
C. I used glue gun with transparent glue. It is enough to wipe off glue residue while it is hot.
Done :)
