New K'nex Roller Coaster Propulsion System
Intro: New K'nex Roller Coaster Propulsion System
This is a new K'nex Roller Coaster propulsion system that uses 2 wheels instead of using a chain. Very practicle. These steps will show you how to build the main part, then you add it to your roller coaster. It uses 2 motor. For me I have one that always run- on motors(left) and one that is remote (right) but you can put 2 run-on motor also.
STEP 1: The Support Base
Make this! This is the base that support the tracks. You may not have to build that if you just want to add it to your roller coaster.
STEP 2: The Tracks
This is how the tracks need to be made, but you can modify it to fit on your roller coaster.
STEP 3: The Motor Assembly #1
This step is to make the frame of the two motor assembly. You need to make four of them.
STEP 4: The Motor Assembly #2
Here you add the motors, wheels, rods and spacers to build the propulsion module. LOOK CAREFULLY
STEP 5: Assembly #1
In this assembly, you have to connect the motors to the tracks.
STEP 6: The Final Assembly
Now install the track on the base support, add elastics to pull the motors upwards, install the tubing on the tracks, and you're ready to go.
IMPORTANT
If the wheel don't grip the wagon adjust the elastics to be tighter.
IMPORTANT
25 Comments
hunter999 10 years ago
lioneatr 14 years ago
Vokomoko 15 years ago
GTRPLR1995 15 years ago
NathanMc 15 years ago
stevoIution 16 years ago
Darth Trainman 16 years ago
bannana inventor 15 years ago
stevoIution 15 years ago
Darth Trainman 15 years ago
sgtmik 16 years ago
Metal4God 16 years ago
I_am_Canadian 16 years ago
the_burrito_master 15 years ago
the_burrito_master 16 years ago
I'm working on a knex coaster blue streak for Cedar point
[http://this is cool but a chain works better but this is more realistic more pictures]
BrazenRain 16 years ago
SeMi_AuToMaTic 16 years ago
