Restoration - New Life Out of a Busted 1930's Radio Conversion
Intro: Restoration - New Life Out of a Busted 1930's Radio Conversion
First of all let me point out that this $35.00 Western Royal console radio was broken, and in my assessment would cost more to repair than to convert into a classy good sounding radio.
I was at my local thrift store a few months ago and saw this radio, its case was not in too bad a shape, but when plugged in nothing happened. I talked them down to 35 bucks, and loaded it up. When I got it home and took the frame out of it, it was apparent that it had been on fire, and that most of the point to point soldered electronics were cooked. I then researched how much a fully functional one would be and perfect ones go for about 300.00 bucks.
So I decided to modernize it, but keep the old look, and make the old controls work a new radio. It needed a full make over and a revamp of everything. The original parts are the knobs, case, metal frame, dial and bezel.
After its conversion its an AM/FM radio with MP3 player, with Bose bookshelf speakers and 150 watts of power.
(2015 update: I also added an input selector switch to the back to choose from AM/FM and Bluetooth link to my iphone)
This instructable cannot cover all radio conversions for all models of radio's, but is a good starting point, its also a complicated build requiring you to think on your feet and come up with your own solutions, I will give you all the information I can.
On to parts and supplies:
STEP 1: Tools, Parts and Supplies Needed
Hammer
Screwdrivers
Soldering iron
solder
drill with bits
jig saw
sanding equipment (orbital sander recommended)
Oven
Parts:
Replacement AM/FM receiver (KLOSS model 1 used here)
Small Mono or Stereo amplifier (Pyle 160 watt used here)
Speaker(s) (Bose bookshelf speakers used here)
Speaker wire
scrap particle board 3/4" thick
Supplies:
sand paper (if your case is in good shape, 400 grit to 1000 grit)
Lexan sheet plastic (available at most hobby shops in 8x10 sheets)
Carpet glue
paint (some cases including mine had black or gold trim)
Varnish
Wood stain
wood filler
1/8" plywood to make cabinet back or paneling.
Balsa wood
epoxy (5min)
Knowledge of electronics, woodworking, and mechanical skills needed for this conversion.
STEP 2: The Radio Before and the Dismemberment.
I started by stripping the case of all hardware:
If you don't know how these radios are put together its pretty simple, all the major electronics are mounted on a heavy metal frame that is easily removed to service and change the vacuum tubes.
Its common for many of these radio's to have the frame bolted to a shelf with thumbscrews, thats how this one was, but to pull the frame out you will need to remove the knobs with a flat head screw driver.
STEP 3: Pulling the Frame and Stripping the Rest of the Hardware.
I recouped some of my money for this project in selling the spare parts online.
The large metal frame was stripped of all parts except the large dial and its tuning mechanism. I removed all the parts above and below the frame.
Later this frame will be used to support the new radio and its equipment.
STEP 4: Refinishing the Cabinet
Because this cabinet was in decent shape, having only a gummy varnish on it, I used an orbital sander and 400 grit to remove the top layer, then the 600 grit to smooth it followed by 1000 by hand to make it silky smooth.
Be very careful and don't sand to much, almost all of the cabinets are made of plywood veneered in thin exotic wood.
I then stained the top center and bottom to simulate the use of different wood as trim.
Then the edge banding was repainted black just like the original, follow this with your favorite finish, I use spray on polyurethane, several coats with light sanding in-between coats.
Your case could need more or less work than mine, or you may want to leave it completely alone and have a very rustic looking radio thats up to date inside.
STEP 5: Grill Cloth Replacement or Cleaning?
I also put the Bose emblem from my speakers on it just for effect.
Should yours need replacement, many places on the internet sell suitable cloth, I have even seen that older semi transparent curtain cloth that would work.
In this picture you can also notice the stained trim.
STEP 6: Speaker Installation
I removed the mount, made of plywood and enlarged the hole so that two speakers siting on a shelf behind the hole could fire out of the enlarged hole.
I will be using a stereo amp so both speakers will be used. You can just use one if you want to go that route.
I had an older set of Bose bookshelf speakers in my closet, most any type of speakers could be used, you just need to match them to your amplifier, you could also use a good set of computer speakers...
I started by making a particle board shelf for the speakers and attaching them to this shelf with wood screws. I also put felt between them to ensure that they didnt rattle.
This was mounted in the base (see the second picture) using wood screws.
STEP 7: Display Cover Replacement.
A little research and I found several sites that offered to sell you a kit to let you make a replacement.
I however made my own using sheet lexan and my oven. Here is the step by step method I used to make a plug or mold for my display:
Wile your at the hobby store getting your sheet of lexan pick up some 3/4inch thick balsa wood. ( if you cant find it then glue some up to that thickness)
Use the original metal bezel ( the part that held the original dial cover) as a guide and trace the inside outline on your balsa and cut it out.
Test fit your balsa plug and make it fit a little loose by sanding it down.
Then round over all the edges like your original, make sure you don't have any sharp edges or dents as they will show up in your new dial cover. The plug should not fit tightly into your bezel, it should have a 1/32nd inch gap all around the edge.
Now peel the anti-sctratch coating off of the lexan and lay it over the the balsa mold/plug, you want at least 2 inches of overhang around the mold. the sheet of lexan you bought will yield two or three usable pieces, and if your like me, I messed up the first one.
Put the mold with the lexan on it, on a cookie sheet and put it into the oven at 300 deg, leave the door cracked and watch as the lexan starts to droop over the mold. This wont take long!
When you see it droop down to the cookie sheet, wearing some oven mitts, quickly remove it, sit it on the stove and push the metal bezel down over the mold and hold it there until it cools.
You now have a new plastic dial cover to trim out and use!
STEP 8: Radio Receiver and Amplifier Selection
I settled on the Kloss model one radio, it has an excellent receiver and has an optional input I could use for MP3 or other inputs. I found a good used one online, you may choose a different radio and you will have to engineer your own connections for it.
I wanted a good amount of power as well, I looked around for a small amplifier to mount on the frame with the radio, I settled on a small sized Pyle PRO style amplifier, they are small and seem to work well, I have used one for a couple of years and its been good.
You could also use a good set of computer speakers and eliminate the amplifier as long as you can get the volume control to the front.
STEP 9: Mounting the Radio and Amplifier
The amplifier was not that difficult, Its only challenge was removing the USB port from it and extending it to the back of the radio, this was done so I could easily reach the MP3 controls and change the USB drive anytime I wanted.
I wont go into to much details on how it was mounted and wired, this is just to give you an idea of hows it can be done, the chances of you finding the same radio that I used as very slim, so you will have to do allot of custom work, just like I did, I will label each picture with as much information as possible.
To extend the controls, some were rewired and extended, and some were left in place and driven with a belt from the old controls using RC car belts and pulleys. The hobby shop was a good resource for this project.
After wiring the components and testing everything for good operation I epoxied all the wiring down to keep it from vibrating.
Only do this after you know everything works fine.
STEP 10: Knobs and Control Mounts
As you can see from the pictures I ran belts from the stock knob controls to the new radio's controls. These were toothed belts used in printers and RC cars. The pulleys were from RC cars. Very strong but cheap.
The station indicator needle uses a string wrapped around the tuning knob shaft, I kept this arrangement, its just for looks but moves when you turn the dial. Its kept tight by a spring in the loop. This was the factory setup, but with a new fishing line string added.
A good way to run your belts is to get them a little longer for your pulleys, and use a plastic stand off bolted to the metal frame for a belt tensioner. Some of the knobs on the Kloss radio were also sanded to ruff them up so the bets would gain traction.
STEP 11: MP3/USB Drive Port and Radio Back
Its mounted low enough that you don't notice it when its running.
The stock radio didn't have a back board covering the electronics, the old stuff had tubes, and tubes were very hot.
This one doesn't get very hot, so I made a dust cover with a few vent holes. Its made from 1/8" paneling painted black with a undercoat paint, this is a rubbery paint that helps it reduce cabinet vibrations.
At higher volumes it rattled quite a bit, this problem was solved by putting felt in-between the back and the case
STEP 12: The Finished Radio
The case was made to get the most volume out of a tiny crappy speaker, with modern ones it has a deep rich tone.
With the mounting method of angling the speakers the way I did, it fills an entire house full of music.
It has an open back design that uses the walls to bounce the sound around as well.
Its great fun to put in a thumbdrive with 1940's radio broadcasts and replay to the Mercury Theater on the air!
Now dont go wild and convert any old radio some of them are very valuable, do your research and find out what its worth.
Some of the RCA ones are worth 1000's
40 Comments
tweakgeek 2 years ago
Cheers :-)
hamza726 2 years ago
PabloK6 7 years ago
Good to know that you enjoy your radio with its new functionality. I respect your decision, but I personally can't stand seeing what you did to that great radio.
Call me a purist, but I feel what you did is like taking a classic 1940's cadillac and dropping the engine off a 1997 Toyota Camry.
helpful55 4 years ago
Sfpeter 6 years ago
Thanks for posting this. I have two General Electric H-87's from 1939, both had sat in a barn for a over a decade. They're uncommon but not very valuable. One had most the internal parts gone but a mint cabinet, the other was repainted and supposedly worked. Both had those early plastic bezels that were corroded. I've spent months trying to think of a radio/amp that would fit in the good cabinet, but I both didn't want to cut it and nothing would fit the holes. This is a simple but effective solution.
As for the person saying this was like putting a '97 Camry engine in a classic car, these old radios only picked up AM and Shortwave. Shortwave is all but gone and AM for decades has been talk radio, so it's more like taking out a steam engine with all it's foibles and putting in a gasoline one. Even just using the tube amp section for the speakers would be tricky. Definitely don't mess up one of the high end Zenith's or a functioning original, but for anon-functional lesser known radio why not?
RichardQ11 6 years ago
MichaelM1352 6 years ago
gemini16th. 7 years ago
Good job- I sort of agree with the "purists" radio restorers on trying to maintain original factory appearance. BUT- at the same time, "they" should realize that there are other non-professionals out there(like myself) that enjoy the retro-audio look just as much as they do, but lack the time or finances for a complete factory restoration(It's hard enough to restore worn/peeling thin wood veneers). Replacing old outdated audio components in these vintage sets with 21st century audio technology is a great marriage of the past & present.
acronus. 9 years ago
Just did a similar project a few Months ago. The radio was a 1950 Eatons Viking in very rough shape. The original tube amp and speaker were toast and the cabinet veneer was flaking and water damaged at the bottom. It's now fitted with a 35 watt PA amp and a pair or JBL bookshelf speakers. Hookup is via 3.5mm headphone jack. The left knob used to control Power/Volume. It's just for power now. The right know used to control tuning, it 's now the volume.
On it's own, it sound ok, but when used in conjunction with a small powered sub, it sounds impressive and really surprises people the first time they hear it.
Total invested into it:
$20 for the radio
$25 for the amp
$20 for the speakers
$40 for the sub
$30 for sand paper, stain, wire, glue, etc
Total $135
Pretty much all sourced from Thrift Stores and Salvation Army.
Video of it finished https://www.youtube.com/watch?v=Ypg7pTJmNf0&list=UUGafiKt4ukQ0-YPON34eQ5Q
nickademuss 8 years ago
awesome little radio!
ShonaD1 8 years ago
I inherited something similar from my grandmother. It has great sentimental value as my mother and her family sat around it during WWII to listen to the war news. A lovely vintage radio console with a magic eye for tuning. The fabric wiring was pretty shabby and a local man rewired it for me and put a nice piece of imported authentic cloth over the speaker. All up less than $100 and he replaced the bulb in the magic eye. I also got the cabinet French Polished which cost me $1000. It works like new and looks great in my front room and it's all ready to pass on to the next generation. You've done a really nice job there.
Thanks for looking! and the kind words. Keep the working radios working is my motto.
wayd 8 years ago
Nice project! Thinking of doing something similar for my vintage 6 volt truck radio -- converting it to modern 12 volt equivalent using pcb's and keeping analog tuner and volume control. Doesn't have to be sophisticated, just play AM tunes is all. Not interested in buying commercial rebuild.
andy.knote 9 years ago
Nice work, I've done similar work and I can appreciate the challenges and how you approach them. Nice work, nice photos and step-by-steps.
jandrews21 10 years ago
nickademuss 10 years ago
indian741 12 years ago
I did kind of the same thing , slight diffrent .
Took a philips BX610A , picked it up @ a yard sale for 20 bucks
It was still working , so i kept the inside .
Bought 2 Bose 101's , small but very awesome speakers.
Bought a quality 2x25 watt amp for 120 bucks ,
Ipod dock @ the top and a build in power suppley
@ the back its just a plug and play system.
Urs looks brand new , awesome , but i like the old / worn look better
And it sounds like bose shut , Awesome !!!
nickademuss 12 years ago
I found a wireless iphone dock that I am thinking of working into this one, right now the jukebox mode of the MP3 player works great, talk radio on AM/FM gets used allot as well.
Bose sure makes good speakers, mine are over 15 years old and they still rock!
robot797 12 years ago
MURDERER
YOU KILLED A RADIO
YOU KILLED HISTORY
but on the other hand nice work revurbishing
(what did you do with the tubes?)
Ebay is were the tubes went, and read the instructable, I revived and improved a broken radio, sounds great to, its the life of the party!
