No Oven-Turkish Flat Bread
5,644
104
13
Introduction: No Oven-Turkish Flat Bread
Don’t have an oven? Want some bread that tastes good alone? Want to make something that your are proud of?? Want to make food that is eatable when you are a beginner? Want to make something that tastes better than anything you have ever tasted? If you answers yes to any of these questions the your in luck because I have the answer!! No-Oven Turkish Bread!! This bread is so easy to make and doesn’t take much time at all. So get a cooking hand and make this bread to show it off to all of your friends.
Step 1: Gather Your Ingredients/Supplies
You wont need much ingredients only a few:
*4 cups of flour
*2/3 cup of milk
*2/3 cup of warm water
*2 TBSP of yeast
*A pinch of baking powder
*A pinch of salt
*Dried Parsley
*Red Chilli flakes
*Savory
*About 3 TBSP of Olive Oil
*5 TBSP of Melted Butter
*A mixer or a hand that can mix for a long time :)
Step 2: Yeast and Water
First add the yeast and the water and mix them well. Make sure that the water is warm. Try to check the temperature so its about no more than 90-100 degrees fahrenheit. Not to hot and not to cold. If it is hot then it will kill the yeast and if it cold it wont activate the yeast. Leave the yeast for about 10 minutes.So be careful with this step. :)
Step 3: Combine the Ingredients
Combine the flour, salt, and baking powder (make sure it is very little). Then mix it very well. After that add the milk and yeast water. Then add only 3 TBSP of olive oil to the bowl.
Step 4: Mix
Mix all the ingredients very well. It will be hard to be honest. What I did was mix it in the mixer then I mixed it with my hands until a dough forms. Then when that is met cover it with plastic wrap until it doubles in size.
Step 5: Cut Into Peices
After it has doubled in size (about 1-2 hours, but you can keep it for however long you like) take it out slowly with changing the shape of it much and cut it into about equal sizes like you would do with a pizza.
Step 6: Roll Into Balls
After you have finished cutting it into pizza slices roll up all the individual pieces into little balls. Then cover with plastic wrap.
Step 7: Bake the Dough
Take one of the dough balls and roll them out then in a pan put some olive oil and put the dough on it. When you see little bubbles starting to form then you flip it to the other side. It is fairly easy. For the temperature what I did is I put it on medium at first then when I wanted to flip it I would change it to low then when I was putting it on the plate I turned it off so it wouldn't overheat. But you can do whatever temperature you want as long as it gets cooked.
Step 8: Butter and Spices
In a bowl melt the butter then add the red pepper (depending on how spicy you want it), parsley, and savory and mix well. (You can add extra spices you like to the mix if you would like). I put about 1.5 TBSP of red pepper, 2 TBSP of parsley, and 1 TBSP of savory. These are just what I put in the mix you can add whatever spices you want. Just note that there is no precise measurement for this step because it depends on how much butter you use and how much you need. :) Hope this makes sense!
Step 9: Finishing the Bread
With the butter and spices you just made apply it to the bread and spread it all over.
Step 10: Repeat
Repeat this process until you have finished all the little balls. Have fun with this step. As you make them you will do all you can to not eat them all. They smell and taste so good.
Step 11: Bon Appetit!
Hope you enjoy eating it more than you enjoyed making it! It is so easy and will take so little time! Make this dish and share the good taste of it!! Also instead of using this dough for flatbread it can be used as pizza dough (which I have done before) or just make one big flatbread! :)
Bread Speed Challenge
This is an entry in the
Be the First to Share
    • Bread Speed Challenge
    • First Time Author Contest
    • Self-Care Challenge
      Self-Care Challenge
    13 Comments
    jockeril74
    jockeril74
    Tip 4 days ago
    For step 2, if you come from a country that uses Celsius instead of fahrenheit - you need to keep the water at about 32-37 degrees.
    Savory - those are aromatic spices - I wish the author would have given more specific names of which spices she uses
    AND I CAN'T WAIT TO TRY IT !!
    Thank you very much !
    Rukbat
    Rukbat
    Reply 3 days ago
    Dry yeast does best in water at 110F-115F (43-46C). (Savory is a spice itself. It's a plant, it looks something like rosemary.)
    budyeates
    budyeates
    Question 9 days ago on Step 3
    Hi, How long do you leave the yeast and water mix before use?
    xstfoc
    xstfoc
    Answer 3 days ago
    Step 2 says to leave the yeast and water about 10 minutes.
    kentsou
    kentsou
    3 days ago
    looks great and simple and will try it, for the yeast fermentation temp I suggest if important then put a range like 80-90F (27-32C) and the type of flour (bread, plain, doesn’t matter?).
    obillo
    obillo
    Question 4 days ago
    Nice work, Miriam. Maybe when half-cooked it can be used for pizza?
    Goofine
    Goofine
    Tip 4 days ago on Step 1
    I can really smell it...looks wonderful
    AllanE9
    AllanE9
    Question 4 days ago on Step 7
    please, what temperature at Step 7?
    d ata
    d ata
    Answer 4 days ago
    The temperature needs to be hot enough to quickly boil water. I would put a little bit of water (a few drops) on the pan and if the water quickly starts to bounce around the pan, it is hot enough. If the water slowly boils away it is too cold.
    gralan
    gralan
    9 days ago
    This is one of the fried bread recipes I've been looking for, and I thank you very much. Really. Have fire, will make bread & BBQ.
    In answer to the previous comment, I use instant yeast, but with regular dry yeast found in typical packets I've used 110-115F degree water & waited until it begins to bubble before proceeding. That's just my experience. It varies with type of yeast, if added to dough first or not, and altitude in some degree. I hope that helps.
