No Weld Chain Break Tool
Intro: No Weld Chain Break Tool
Chain break tools are used to remove pins from bike,scooter, or motorcycle chains so that they can be resized.
I have seen several videos recently showing people making their own chain break tools. Each one required welding equipment and knowledge. I have neither, so I thought to myself, “I wonder if I can build a chain break tool that requires no welding?”
Challenge accepted. Here are the results.
STEP 1: Make a Push Pin
Thread a jam nut on a bolt. Put the bolt in your drill, head & nut first. While slowly rotating it in your drill, rub the end of the bolt against a spinning grinding stone until you reach the desired thickness. It should be smaller in diameter than the chain pins you will be removing.
Once you’ve reach the desired thickness, slowly back the jam nut off the bolt until it is removed. This will repair the threads where the ground-down part begins.
Finally, epoxy a washer on at the head of the completed push pin.
STEP 2: Attach the Guide Nut
Using epoxy, attach a jam nut to one of the middle holes on a mending plate. Make sure it is centered, as this will be what guides the push pin. You can use a bolt to make sure it is lined up properly. Be careful not to get any epoxy in the threads of the nut. Let the epoxy fully cure before continuing.
STEP 3: Assembly
Pictures do more than words. Assemble your tool as pictured.
STEP 4: Start Breaking!
Align the chain pin directly under the push pin, so that it lines up with the chain pin you want to remove. Adjust the tool depth using the wing nuts as needed. Use a wrench to slowly drive the push pin until it has pushed the chain pin out enough to remove the roller link.
If you’ve never broken a chain before, here’s some advice: Don’t push the chain pin all the way out. You want to leave it attached to the outer link for proper reassembly.
STEP 5: Conclusion
I built this for the fun of it and to see if it could be done.
It works, so I’m happy with it. However, my real chain tool works better, so this will be relegated to my junk pile until I need to scavenge the parts for another project.
Thanks for reading.
5 Comments
keets 3 years ago
You end the instructable with the answer on my question and when I thought a bit longer about it......
It works, so it can be a live saver if you don't have a real one at a sunday morning and the stores are closed. Or the stores ar far away, than this can really make your day!
Nice instructable!
Chris11cc 1 year ago
D shackle chain breaker
10mm D shackle
M10 bolt
Clout or nail
Cut nail to length and remove tip file flat
Drill hole in end of bolt to interference fit the nail
Hammer nail home ensuring not to bend
Voila Job done
Use what you have at hand
P.s. added washer and nut for easy of tool
shepnstein 7 months ago
shepnstein 3 years ago
That being said, I've been going stir crazy with this whole pandemic so it did provide a little entertainment
