Node-RED: RS485 Raspberry Pi Tutorial
Intro: Node-RED: RS485 Raspberry Pi Tutorial
The flow based visual programming tool Node-RED becomes more and more popular for Raspberry Pi developers. This instructable will show you how to use our isolated RS422 / RS485 Serial HAT under Node-Red for simple RS485 communication and for MODBUS applications too.
STEP 1: Tools and Materials
Materials:
- Raspberry Pi A+, B+, 2B, 3B or 4B
- RS422/RS485 serial HAT
- SD Card
Software:
- Raspbian Stretch or Buster (with desktop and
recommended software)
STEP 2: Free the UART in Raspbian Stretch or Buster
The easiest way is to use the raspi-config tool to switch the UART to the GPIO14/15 pins. take a fresh Raspbian image
- sudo raspi-config
- goto '5 Interfacing Options'
- goto 'P6 Serial'
- 'Would you like a login shell to be accessible over serial?' --> NO
- 'Would you like the serial port hardware to be enabled?' --> YES
- Finish raspi-config
- reboot the Raspberry Pi
Now you can access the UART via /dev/serial0
STEP 3: DIP Switch Setting for RS485 HAT
Our RS422/RS485 HAT comes with 3 DIP switch banks. You have to set these DIP switches for RS485 as shown in the picture above.
- Switch 1: 1-OFF 2-ON 3-ON 4-OFF
- Switch 2: 1-OFF 2-OFF 3-ON 4-ON
- Switch 3: 1-OFF or ON* 2-OFF 3-OFF 4-OFF
*Depending of the position of the RS422/RS485 HAT in the Modbus line you have to switch the terminating resistor ON or OFF. Please switch the resistor to ON position only if the HAT is on one end of the bus line. In all other cases switch the terminating resistor OFF
STEP 4: Start Node-RED
Start Node-RED:
Node-RED is part of Raspbian Stretch and Buster (with desktop and recommended software). You can use the node-red command to run Node-RED in a terminal or on the desktop via the 'Programming' menu.
Open the editor:
Once Node-RED is running you can access the editor in a browser. If you are using the browser on the Pi desktop, you can open the address: http://localhost:1880.
STEP 5: Simple RS485 Communication
In this example flow the Raspberry Pi will send the text 'Hello World' via the RS485 after pressing the inject button. The flow will receive incoming strings (terminated by \d) and show the string in the debugging window on the right side.
The communication will be realised by using the serial in and out nodes, which are pre installed. It is very important to set the properties of the Serial Port to /dev/serial0 as in the picture above.
You can test the flow with a connected PC (via an USB to RS485 adaptor) and a simple terminal program.
STEP 6: MODBUS - Configuration 1
In the following steps I want to show you how to implement a simple Modbus RTU communication under Node-RED.
First we have to install additional Modbus nodes node-red-contrib-modbus via the palette manager or on the bash by entering:
npm install node-red-contrib-modbus
Now you can import the flow.
STEP 7: Modbus Configuration 2
After importing the flow we can take a look in the configuration of 'Modebus write' and 'Modbus read' nodes. It is imortant to set the 'Server' property to dev/serial0 and configure it as shown in the pictures above.
STEP 8: Modbus Test
For the test I've connected an Arduino with RS485 Shield as Modbus slave (you can check this instructable for more information).
Modbus Read will poll Unit 1 all 2s and read 8 registers of the slave. You can see the result in the status of Modbus Response. Via the 2 injectors you can set the register 6 of the slave to 0 or 255.
12 Comments
toreplatz 4 years ago
At the step 5 already, the system doesn't recognize the serial port, and node-red show in the log that permission is denied.
The process is not easy, could you revisit the procedure and upgrade (and more detailed) the post with the new version of raspbian?
Thanks
Zihatec 1 year ago
I've tried today a brand new Node-Red installation under Bullseye - running on a Raspberry Pi4 without such problems. Every old example flow was running on the scratch....
Zihatec 3 years ago
with the latest Raspberry Pi OS and a Raspberry Pi 4 and it works well
on the scretch. Please see my comment on the top too!
ALPF5555 1 year ago
I have a USB Zigbee 3.0 dongle in a USB port and a SSD in another USB port then the Hat plugged on the top of the pins and have tried to get it to do the simple thing and it will not show message in debug window
Zihatec 1 year ago
What is connected on the RS485 side? Notthing? In this case you will
not receive data in the debug window! For the basic example you have to
connect for example a RS485 USB adaptor and your PC as "other" RS485
device. With a terminal program you can send from the PC messages via
RS485 to the HAT and only in this case you will receive something in the
debug window.
I've updated flow1 in Step 5 today. With the dip switch setting
S1: ON-OFF-ON-OFF
S2: OFF-OFF-ON-ON
you can "see" on the UART the self sended messages by the HAT on the RS485 side and you will get the "Hello World" message in the debug window....
crafetzeder 3 years ago
Find here some read/write examples:
https://pastebin.com/u/rafi_chris
Unfortunately, the mentioned node red package raise errors. (FSM errors if multi IDs are used)
In my setup I'm using only one Getter and one Writer Node and I thought the state machine issues disappear with just one note. But, NO - It seems that for each slave address a new state machine is created.
Nevertheless, my setup is running stable.
Novellus 3 years ago
I'm using two USB to RS-485 converters cross connected to each other in a configuration which I can make work correctly using a Python script I wrote. On the Raspberry Pi one of them becomes ttyUSB0 and the other becomes ttyUSB1. Settings are 19200, 8,N,1. When "deploying", both of these ttyUSBx ports are seen by Node Red.
Node-RED version: v1.3.3
Node.js version: v10.22.0
Linux 4.19.97-v7+ arm LE
Just like torplatz noted in his message, I struggled to get past step #5
Note that my own Python script can successfully transfer data from ttyUSB0 to ttyUSB1 (and vice-versa). Following the guidance in this Instructables did not deliver a payload to the "Debug Window" - It really should.. So after more "trying different things", I landed on a working set-up - I'm attaching images of my working system.
NOTE: I've added a "Bonjour" payload node for testing purposes.. just to confirm that some nodes can work. I also have a node for ttyAMA0 (the on-board UART) which also works when connecting those pins to a TTL to RS-485 Converter.
The TWO "blue" USB to RS-485 that become "ttyUSBx" which I used here are actually pretty nice, They have a Red LED that blinks on Transmit, and a Blue LED that blinks on Receive - very useful for troubleshooting purposes.
As for the TTL to RS-485 adapter, I used a low cost unit from eBay.
Zihatec 3 years ago
with the latest Raspberry Pi OS, a Raspberry Pi 4 and our own HAT and it works well
on the scretch!
Please see my comment at the post of toreplatz too.
Some additional comments about your post:
1.) RS485 is a differtial serial interface. In dÃfference to a RS232 you have not to make a "cross-connection" between the wires for RS485 (half-duplex). "A" must be connected to "A" and "B" must be connected to "B" !!!!
2.) This instructable is written for our RS485 HAT. This HAT is using the on-board UART of the Raspberry Pi. Please note: You can use /dev/ttyAMA0 to send and receive data to the on-board UART, but the better and more modern term is /dev/serial0 as in the description.
3.) Simple TTL to RS485 converter from Ebay comes often without any auto transmitting feature. In this case you have to control the transmit/receive mode of such adaptors via an GPIO port.
4.) It is possible to test the function of the on-board uart (and of the USB ports with serial converters too) with a simple terminal program for example Minicom. No needs to write a Python script for this job. I've used for my tests Realterm on my PC connected via an simpe USB-RS485 converter to the RS485 HAT on the Raspberry Pi.
From the begining I understood that your Instructables was geared to your own product, but Node-RED (as shown in your own images) does not specify your product, but standard "Linux" port names - in that sense it makes it very generic, and means that your Instructables should function correctly. No special configuration required.
On a side note.. I use (and like very much) Realterm as well it is a very versatile program. The industrial environment where I work, i use a large variety of RS-485 devices and interfaces.. On a daily basis we work on the design, build and test of control systems using RS-485 (RS_232 to a lesser extend).
P.S. - I also replied to one of your messages at the Instructables.
Zihatec 3 years ago
I bought the same card of the tutorial, but others operations needed to make it work.
Can you help me, please?
