Introduction: Nokia Phone Cheat Codes
Here are some cool cheat codes for nokia phones...........
Hope you enjoy..................
Pls Subscribe..............
Step 1: The Codes
Type the following code in you nokia phones (Depends on phone model):-
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# – Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# – takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair – if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# – Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* – (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* – Half Rate Code deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
*#7328748263373738# resets security code.
Default security code is 12345
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Enter the menu of warranty codes. In fact, you do not need, but you can find them using the arrows scroll menu.
Menu:
Shows the serial number of the device. Date and year of manufacture (eg 0299). Shows month and year of sale (if installed). Here you can set the date, but be careful – it can be done only once in their life phone Date of last repair (if any) Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
EFR CODEC (Enhanced Full Rate)
This function with its inclusion on the idea, should significantly improve the quality of speech, but unfortunately, it must be supported by your connection. When the work is slightly increased power in the phone call (about 5%). How do I know, none of the Russian cellular operators do not support this feature. Principle is based on a different compression algorithm for speech recognition (ACELP) and has a wider bandwidth.
SIM Clock
Stop allowed
Warranty Codes
25 Comments
Question 3 months ago on Introduction
Nokia 6230 display test mode?
Network unlock code for Nokia 105 RM-1134
5 months ago
Nokia ta 1188 cords for factory reset
5 months ago
How can I use secret code to factory reset Nokia Ta1188?
6 months ago
Nokia ta 1034
7 months ago
How to unlock my Nokia 105 TA 1010
IME IS 356005089335672 Thanks Manzi
11 months ago
Pls how can unlocked my unknown password for Nokia TA 1010
Question 2 years ago
How do i remove secret code for Nokia TA 1010. Please help me
Answer 11 months ago
How can I unlocked my unknown password for Nakia T-A 1010
Question 1 year ago on Step 1
my nokia 130 is locked i forgot the password any solution?
Question 1 year ago
How to reset Nokia 105 Model TA-1010......35??????????????????????code
Orakzai
Email: rorakzai@gmail.com
Answer 1 year ago
Hiya pal. I've just seen the message that you posted 11days ago with the code to wipe the you know what starting with 35?????????????. Can you please send it to me asap. Thank you my brother
Answer 1 year ago
Code to unlock Nokia 1010 thank you
Question 2 years ago on Introduction
How can i unlock my nokia 6101 phone security code?
2 years ago
Nokia 111 code
nokia ta-1010 lock sceen open process but lock not idea
2 years ago
very nice
I NEED NOKIA 301 DUAL SIM COD
purchase code kon sa h
