Note & Playing Card Holder
Intro: Note & Playing Card Holder
This was meant to just be something that you could set your notes in to view them all but you can also use it as a playing card holder for games.
STEP 1: Tools & Materials
I used quite a few tools but you can still make this if you at least have a chop saw, few clamps and sand paper.
Tools that I used:
- Chop Saw
- Table Saw
- Router
- Planer
- Sand Paper
- Clamps
Wood:
- Pine from a 2x12
- Oak
- Not really sure what the last type was but it had a cool green tinge.
STEP 2: Cutting and Joining the Wood
The end goal of these next 2 steps is to have a block of wood that is 1 1/2" thick x 1 3/4" wide x 10 1/2" long. So if you would like to you could just get a piece of scrap wood and cut it to those dimensions, I however decided to mix it up a bit.
My design went like this:
- Oak (1/4" thick)
- Green (1/8" thick)
- Pink Pine (3/4" thick)
- Oak (1/4" thick)
Once you have your wood cut lay your design out, then glue and clamp it.
STEP 3: Rough Cuts and Sanding
Cut a little less than a 1/2" off of each end then sand or plane the top, bottom and sides.
STEP 4: Adding the Angled Notches
Didn't take pictures for this step but all I did was angle my table saw blade to 20 degrees and make 3 cuts in the block.
STEP 5: Sanding & Finshing
I used a router and rounded the front edge then proceeded to sand it. To finish it I just used cutting board oil since that's all I had.
Later I decided to drill a small hole in the back big enough for a 1/4" dowel to sit in just incase someone wanted to stand taller paper up in it.
Penolopy Bulnick 7 years ago
Love the design :) Would be great for greeting cards too :)
